Old 03-04-2009, 12:46 AM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Has anyone actually confirmed....
that slam specialties bags have internal bump stops? I know it's been talked about and whatnot, but I'm curious if anyone has actually seen the inside of an RE7. and better yet, if someone has some pics.
IvelDesigns is offline   Reply With Quote
Old 03-04-2009, 01:42 AM   #2
Twisted Minis
Twisted Minis's Avatar
Re: Has anyone actually confirmed....
I know a guy that cut one in half to see. Sure enough, it's there. They also won't compress as far as a Contitech or Firestone bag.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 03-04-2009, 08:35 AM   #3
Rokcrln
Rokcrln's Avatar
Take a flashlight and look in the air hole and you will see a 9/16" or so stud in the bottom. When aired out this stud contacts the top plate. Simple and effective.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-04-2009, 01:42 PM   #4
Bowtie468
Bowtie468's Avatar
Sure thing ! I double checked my RE-8's ! It's in there. It's also the reason the air inlet is offset from the mounting holes !
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 03-04-2009, 06:11 PM   #5
Shane
Shane's Avatar
I've been told that the "bump stop" in the Slam products was NOT designed to support the entire weight of the vehicle. Anyone else heard this?
Shane is offline   Reply With Quote
Old 03-04-2009, 09:43 PM   #6
Bowtie468
Bowtie468's Avatar
I had not heard that before, but i would believe it, as the bumpstop is nothing more than the boss for the threaded mounting hole.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 03-04-2009, 10:58 PM   #7
Scottshotrods
The slam bag does have a internal bump stop we taken a re-6 and re-7 apart
at our shop 5 years ago when we made the switch from firestone to slams for
our frontends.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 03-04-2009, 11:28 PM   #8
pissonNOS
senior member
pissonNOS's Avatar
our frontends.
Justin
i dont know why more places arent doing like you guys i never understood that if you look at the 2 bags side by side cut inhalf the slams look alot better IMO
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 03-04-2009, 11:51 PM   #9
Shane
Shane's Avatar
A lot of folks dislike slams due to the fact that when deflated they are not as short as other brands.
Old 03-04-2009, 11:57 PM   #10
pissonNOS
senior member
pissonNOS's Avatar
fair enough
69 GMC bagged
Old 03-05-2009, 12:04 AM   #11
IvelDesigns
if anyone has some pics, i'd love to see them. not really concerned as I used RE7's in the past, and plan to use them in the future. i'm just curious.
but not curious enough to cut open a bag
Old 03-05-2009, 02:45 AM   #12
Twisted Minis
I don't run Slams myself because the spring rate is too stiff for me. I like the soft spring rate of Contitech and Firestone bags. And both of them have been making bags forever.
That said, I like to use external bump stops on any bag I run. I also like to use Limit straps when I can to keep them from over extending as well.
Old 03-05-2009, 11:06 PM   #13
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I slam the front of mine down on the internal bump stops in my RE7's with 1/2" dumps. Yes, it hits kinda hard.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-06-2009, 08:38 AM   #14
tds
but spread over 4 bags i would assume you would be more then fine...
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 03-06-2009, 09:10 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
You could be right, but why push it. I would run bump stops regardless. This ensure that your bag isn't getting stressed, pinched, etc while you are parking lot cruise when aired out.
I had an exhaust failure that caused a supply line to blow while I was in the middle of nowhere. I drove on the paved shoulder of the highway for about 5 miles to get to a rest stop. When the exhaust was repaired and the damage was assessed, all I needed was a a piece of air line.
Had I been riding on internal stops rather than real bump stops I think the outcome would have been much different.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-09-2009, 10:14 AM   #16
Number98
Prestige Worldwide
Number98's Avatar
Hopefully this is not too far off the original topic, sorry if it is.
I seen someone mention "limit straps", we use these on race cars to keep the rear end from dropping down so far that the rear coil springs come out of their pockets when the car is on jack stands....
Saying that I was curious about a few things.
I have never ran an air bag set-up before but I was wondering about this, when the truck is placed on stands do you guys let the rear end hang from the bags? I know the panard bar limits distance but I would think the rearend would still be pulling down on the bags?? I would think this would be a bad thing.
On the fronts, there would not be a problem because the upper A frame would bottom out and limit that travel distance correct?
Number98 is offline   Reply With Quote
