Old 03-04-2009, 01:28 AM   #51
bird7263
Urban Chop Shop
bird7263's Avatar
Re: Poor mans drop
Originally Posted by Shane View Post
Opinion has nothing to do with it. It's now useless to further this discussion because it is very apparent that you do not understand scrub-line & interference issues a block of this size has on a trailing arm set up.
I only hope & pray you do not have a flat on the rear of that truck with the 3" blocks when me, my family or someone I know is on the same road as you. I also hope you are not injured when, not if, this occurs.
Good luck.
I am not trying to argue.. I am only saying that I personally have never seen a problem.. I do understand what would happen if you get a flat. And I do understand scrub-line & interference issues. You are correct on that. I am only offering suggestions that have worked for others and my self. However I have seen a few airbagged and vehicles’ on air fail sparks flying while dragging frame down the freeway.
I apologize to Allen if it seems like I started an argument. This is your thread not mine.
That is one thing I love about this site everyone is very passionate about there trucks and there opinions.. That is what makes our country great. Thanks to you guys that work here and take time out of your days to make this forum happen.
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods
1965 Chevy 1/2T Longbox, soon to be a slammed shop truck
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266
Semper Fi Marines
bird7263 is offline   Reply With Quote
Old 03-04-2009, 04:49 PM   #52
allen123
It'll buff out
allen123's Avatar
Re: Poor mans drop
No your fine you have helped out alot
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 03-05-2009, 07:31 PM   #53
dmartin1
dmartin1's Avatar
Re: Poor mans drop
cutting the fronts is good,but soemtimes the tires tend to wanna lean in if you go too far(like slammin on the ground)
we've heated many springs,many times.
our 1978 chevy c10 is riding on heated springs for about 4-5 years now,and we've even hauled a load in it.it didnt make a huge effect on the ride,you just feel a tad more here n there,but not bad.
and it sure is cheap
dmartin1 is offline   Reply With Quote
Old 03-05-2009, 11:38 PM   #54
Shane
Shane's Avatar
Re: Poor mans drop
yeah it's cheap, but why take the chance of a broken spring when you can pop the lower ball joint, cut the spring and reinstall and KNOW the spring hasn't lost it's temper?
for that matter, cutting it is just as cheap
Shane is offline   Reply With Quote
Old 03-12-2009, 03:35 PM   #55
63 & 64 Bowties
and a few others
Re: Poor mans drop
Originally Posted by allen123 View Post
Do you have any pics with the chevelle springs with blocks and cut springs so i can get a idea of how low it will look
Here's my 63 with 70's Chevelle springs (no blocks) in the rear and 1.75 coils cut off the fronts. I had to remove the bump-stop mount on the lower control arms.
All very easy and very cheap. It's not a 67-72, but it should give you an idea what it looks like.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
Last edited by 63 & 64 Bowties; 03-12-2009 at 03:36 PM. Reason: felt like havin' a peanut butter & jelly sandwich
63 & 64 Bowties is offline   Reply With Quote
Old 03-14-2009, 03:28 PM   #56
nvr_di
nvr_di's Avatar
Re: Poor mans drop
What other springs will fit the rear of our trucks? Im lookin for around 5'' in the back. I'll probably end up buying drop springs but I just like knowing my options.
nvr_di is offline   Reply With Quote
Old 03-14-2009, 05:26 PM   #57
Shane
Shane's Avatar
Re: Poor mans drop
4 inch springs and a 1 inch block will get ya there.
Old 03-15-2009, 08:44 AM   #58
67slammer
67slammer's Avatar
Re: Poor mans drop
i have 3 set of belltech spring for a chevy celeberty that look like the rear springs in our trucks, they are wound real tight top and bottom. i will try to get some pics today. mike
67slammer is offline   Reply With Quote
Old 03-17-2009, 05:09 PM   #59
nvr_di
nvr_di's Avatar
Re: Poor mans drop
anyone happen to have a list of what will fit? You never know what one will come across in the yards.
Old 03-17-2009, 05:15 PM   #60
jrods70
jrods70's Avatar
Re: Poor mans drop
Welcome to the board! You may not have realized it, but you have to be a subscribing member to post for sale messages. Check out the provided link for details on subscriptions.
jrods70 is offline   Reply With Quote
Old 03-19-2009, 10:45 AM   #61
coast2coast
coast2coast's Avatar
Re: Poor mans drop
Agreed, a list would be nice. It sounds like a jeep TJ, a chevelle, or a g-body (regal, malibu, monte carlo) rear spring should work. And give you about 2" drop.
Anyone know of an original equipment spring that would provide more drop?
coast2coast is offline   Reply With Quote
Old 04-02-2009, 08:34 PM   #62
bowtiedriver2
bowtiedriver2's Avatar
Re: Poor mans drop
<----- In need of the poor mans drop. I would really like to find out what is the least expensive way. Can't justify drop spindles and converting to discs right now.
anyone know where to get U-bolts made around northern IL? I am thinking of cutting one coil in the front and going to CJ springs with 2" blocks in the rear.
'69 LWB Stepside, 350 with mild mods, and 3 speed on the floor
Intentions...383 sbc (in assembly stage), trans is still not a definate (3, 5, or 6 speed?), 3/5 drop, power disc brake conversion...then some body work.
bowtiedriver2 is offline   Reply With Quote
Old 04-04-2009, 02:09 PM   #63
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Poor mans drop
Originally Posted by Longhorn Man View Post
nothing wrong with cutting the fronts. Don't take out too much, but it's oK. Ride will suffer, but it isn't as bad as some will have you believe.
heating the rear is OK, but not prefered.
Some will tell you how they will shatter or ride like crap, or what ever.
They were doing this to coils untill the 80's when they started making drop coils.
it isn't prefered, but it isn't gonna be as bad as most want you to think.
how many coils can you take out
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 04-06-2009, 01:10 AM   #64
chopper103in
chopper103in's Avatar
Re: Poor mans drop
dont know exactly where your at but elgin spring in elgin might be able to help you out
they are on larkin ave north of us20 about 6 blocks i think
69 chevy swb
2.5 in droped spindle with 1 coil cut--5 in dropped spring in rear
5 in dropped spring
307 repaced soon with 350
3sp on tree soon replaced with 350 tubo
06 monte carlo
94 chrysler town & country---198K
84 jag xj6
76 sportster---57 panhead
chopper103in is offline   Reply With Quote
Old 04-06-2009, 06:58 PM   #65
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Re: Poor mans drop
Here is a pic of the heated coils I pulled out of my truck from the last guy. Every spring was collapsed and it ended up riding on 3 of the four bump stops and ripping out the front shocks.
I have cut the coils many times. Worst part, if you cut too much you don't have a suspansion anymore, you have a brick.
Second part to consider is that used springs have diffrent sag. Just because your truck sits level now, does not mean it will after the cut even if you remove the same amount from each spring. Put the springs back from the side you pulled them out of and a good thing about our trucks is that you don't have to remove a whole coil at a time. Which means, if one side is higher you can just pull it again and trim a little to level the truck out.
Lastly, stick to the two coil rule. If you need more than that, you want to get it elsewhere. If you are like most and want a lot of drop, start with 1 to 1-1/2 coils. Do not build up too much heat during the cut or the tension will change which means the ride will change. Hacksaw, cutoff tool, or plasma. Stay away from the torch.
Good luck and enjoy!
Hard Luck is offline   Reply With Quote
Old 04-06-2009, 09:42 PM   #66
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Poor mans drop
i cut 2 off and it was too much i had to put chains on the control arms to keep the springs from falling out when i jacked it up
Gage
Old 04-15-2009, 09:45 AM   #67
VanceH
Loving the Jimmster
VanceH's Avatar
Re: Poor mans drop
Ok i know there is alot of controversy on doing this the old school or cheap way, but this is what some of us get to do. So with that said, if i cut my front springs (in small increments) and do the same for the rear springs, do i still need the rear blocks?? I am trying to lower the front about 1.5 and rear about 4.5. it is really raked at this time and i dont like the look.
VanceH is offline   Reply With Quote
Old 04-15-2009, 09:50 AM   #68
Skirkpat
Skirkpat's Avatar
Re: Poor mans drop
I would say no to both, but just a many would say yes to the front....The backs are not able to be cut, 2" lowering blocks are as big as you can go "Safely" ..... Neither should be heated.
Skirkpat is offline   Reply With Quote
Old 04-15-2009, 09:53 AM   #69
VanceH
Loving the Jimmster
VanceH's Avatar
Re: Poor mans drop
ok thanks and i do understand your position, if you use blocks then you dont have to cut the rear springs or replace them with shorter springs?? i guess i dont understand.
Old 04-15-2009, 10:06 AM   #70
63 & 64 Bowties
and a few others
Re: Poor mans drop
you can't cut rear springs, they're pigtailed on both ends. Get used Chevelle or Jeep springs, or new lowering springs from a vendor.
Old 04-15-2009, 10:08 AM   #71
VanceH
Loving the Jimmster
VanceH's Avatar
Re: Poor mans drop
Perfect!! i did not know they were pig tailed on both ends, ok so lets say i buy some drop springs for the rear, do i still need blocks??
Old 04-15-2009, 10:37 AM   #72
Skirkpat
Skirkpat's Avatar
Re: Poor mans drop
"Perfect!! i did not know they were pig tailed on both ends, ok so lets say i buy some drop springs for the rear, do i still need blocks??"
If you need up to 2 more inches of drop? figure out where you want it and it will be easier to know how to get there?
Old 04-15-2009, 10:50 AM   #73
VanceH
Loving the Jimmster
VanceH's Avatar
Re: Poor mans drop
I am wanting to drop my front 2 inchs and my rear somewhere between 4-5. I am looking for rear springs and have found a "Stepped A arm"? looks promising.
Old 04-15-2009, 12:08 PM   #74
terribleone
terribleone's Avatar
Re: Poor mans drop
I took my springs to a suspension shop and they de-arched them for $25.
Got 2.5" lower. Easy cheap and safe.
terribleone is offline   Reply With Quote
Old 04-15-2009, 12:25 PM   #75
Frizzle Fry
Frizzle Fry's Avatar
Re: Poor mans drop
You are talking leafs now. Most of this thread refers to coils. Good info though.
3" blocks are too tall for a trailing arm-type setup.
Shane is right; for 15" wheels. When you go bigger you can run a taller block accordingly. Rule of thumb is +0.5" in block for every +1" in wheel diameter. With that said, I run a 3" block with 22" wheels. I wouldn't want to run much taller blocks than that regardless of scrub line tolerance.
Frizzle Fry is offline   Reply With Quote
