Old 03-04-2009, 05:30 PM   #1
Tagg33
Tagg33's Avatar
Question How to: remove steering column shifter arm for good
I have a 84 GMC that was once a column shifted truck. The shifter arm has already been removed from the column but otherwise all the internal parts are the same. I seem to remember an episode of Musclecar on Powerblock TV were Rick showed how to remove the necessary parts and with a little work the column looked like it never had a shifter. Does anyone know what the steps are? How do I remove the linkage arm at the bottom of the column. I attached a pic of the bottom of my column you can see a tensioner is being used to keep it from rattling and moving.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 03-05-2009, 12:12 AM   #2
ostncoln
ostncoln's Avatar
Re: How to: remove steering column shifter arm for good
i think i saw that episode. i know he used jb weld on it somehow
1971 C-10 Project
350/400
5/7 drop
My Slow Build Thread
ostncoln is offline   Reply With Quote
Old 03-05-2009, 11:52 AM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I cut mine clean off.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-05-2009, 12:10 PM   #4
Tagg33
Tagg33's Avatar
You cut off the linkage arm? Do the leftover parts in the column rattle? Or is there more to remove?
Ryan
Old 03-05-2009, 02:34 PM   #5
smashingchuck
yes, and welded a piece of sheet metal over the hole. and no they don't rattle at all. I never even thought about it again until this thread came up. I did this 8 years ago.
78 Build Thread
4Runner Build
Old 03-05-2009, 02:45 PM   #6
HotRodYJ
HotRodYJ's Avatar
How are you guys cleaning up the shifter sleeve inside the truck?
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 03-05-2009, 03:05 PM   #7
Tagg33
Tagg33's Avatar
Smashingchuck: I am going to be welding up all the holes in my firewall and removing the big bracket around the brake booster and column. What did you do on your truck to clean up the firewall where the column comes thru? I just went thru your build thread again and your firewall looks amazing.
Ryan
Old 03-06-2009, 12:37 AM   #8
smashingchuck
Thanks Man! I cut the whole area out right from where the two pieces of sheet metal overlap all the way down to the floor, and welded in a piece of 1/8" steel. I used the same method on the other side. All other holes were done separately, one at a time.
Haven't gotten that far yet... but I don't think It's anything a little grinding and filler won't fix.
78 Build Thread
4Runner Build
