Old 03-04-2009, 08:48 PM   #1
bradf74
project of gauges in a 79 dash
After searching numerous threads on this site about newer gauges in a 79 dash I have tried my own thing.
These are cheap ($20) O reilly (equass, maybe) water temp gauges. I bought only 1 of the 4 I need becuase I am just test fitting this. I also bought a $10 spare plastic dash from the local pull a part to try this out.
I Dremel cut the back "half" of the original plastic dash.
The gauge has a plastic threaded plastic ring that threads onto the gauge itself to hold it into the dash.
just push it through and thread it in..
I know it is not perfect, but this is a work in progress. I will get out a file and smooth all the edges. I also do not know if the bigger speedo and tach will fit the other larger holes. I plan on tacklin that next.
bradf74 is offline   Reply With Quote
Old 03-04-2009, 09:35 PM   #2
S10Fan
Old Heap Driver
Re: project of gauges in a 79 dash
The gauge looks pretty sharp for a cheapie.
Keep us posted, looks good.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-04-2009, 09:59 PM   #3
vtwinsport
vtwinsport's Avatar
Recessed look is always nice. here is a similar thing I did with front mounted gauges.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 03-04-2009, 11:01 PM   #4
BruthaMan
US Army Veteran
BruthaMan's Avatar
That's pretty slick, Brad! Looking forward to seeing the next step.
BruthaMan is offline   Reply With Quote
Old 03-04-2009, 11:40 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
that's the same gauges I used almost half the price of Auto Meter
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-04-2009, 11:49 PM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-05-2009, 12:26 AM   #7
keith61760
keith61760's Avatar
Looks Good! I'm partial to those gauges. I used the same line of them in the stock bezel. Don't have a pic of them finished, but they will have the stock surround on it. It's still a work in progress.
keith61760 is offline   Reply With Quote
Old 03-05-2009, 12:43 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by keith61760 View Post
Looks Good! I'm partial to those gauges. I used the same line of them in the stock bezel......
So what are they?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-05-2009, 01:15 AM   #9
keith61760
keith61760's Avatar
Originally Posted by N2TRUX View Post
So what are they?
I guess that would help. Equus 7000 Series are the ones I have. Chrome ring, black gauge face. Got the Speedometer, Tach, Fuel separately then the volt, oil water temp as a set. They were on sale at Kragen plus military discount. I think the 3 piece set was 20, fuel was 20 and the speedo and tach were around 50. As far as I can tell they are accurate to what the stock gauges were. Just took this pic. Still not much more progress LOL.
Old 03-05-2009, 03:13 AM   #10
flamingbig10
6.0 powered square
here the equus site, Mine are the 8000 series I think I'm going to make mine like yours Keith
Aaron
Old 03-05-2009, 09:21 AM   #11
keith61760
keith61760's Avatar
I couldn't find this pic last night. I cut the stock housing to fit the gauges and wiring. I sanded down the black face plate and cut the holes a little bigger so the gauges would fit. Mine was actually metal. I cut the smaller plate so the speedometer and tach would have something to mount to and mounted it in between the housing and the big black plate. You can barely see the that it is there once assembled. I had more pictures but I can't find them right now. I used LED's for the turn signal, brights and parking brake indicator.
Old 03-05-2009, 05:01 PM   #12
bradf74
I was thinking about taking out the old "housing" and everything behind the outer plastic dash. I would only have to tie in my guages to the old harness in a couple places. All my guages are mechanical.
Old 03-05-2009, 06:19 PM   #13
keith61760
keith61760's Avatar
The Oil press and water temp on mine are mechanical. Just had to run the lighting wires. I kept that back housing mostly for mounting support for the black metal piece and the bezel. I thought I had better pics but I can't find them. I'll have to try to get better ones.
Old 03-11-2009, 06:25 PM   #14
bad_burb
bad_burb's Avatar
Any updates?
'73 C-30 3+3 Dually 454/TH400
'74 Fleetside 350/TH350 (SOLD)
'69 Nova 350/TH350 (project FOR SALE)
'63 Nova 305/TH350 3.73 posi (the wife's project)
bad_burb is offline   Reply With Quote
Old 03-11-2009, 07:22 PM   #15
88 Dippy
88 Dippy's Avatar
i beleive my truck has newer style guages in it all ready. it has a VOLT guage, oil PSI, and whater temp (the last is a solid blank)
what is the diffrence between the tow styles?
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 03-11-2009, 09:36 PM   #16
bradf74
No not yet.. I am wiating till next week to get the larger speedo/tach. I want to make sure those fit before I go to the trouble of all the little gauges. will post when I see how they will fit.
Old 03-11-2009, 11:01 PM   #17
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
i got my gauges for 5 bucks apiece
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 03-12-2009, 12:39 AM   #18
keith61760
keith61760's Avatar
Are you using the Equus gauges for the tach and speedo too? They are smaller than stock, thats why ended up attaching them to a piece of metal. With the bezel on they look fine. I'll have to grab a bezel tomm and take a pic with it on.
Old 03-12-2009, 10:39 AM   #19
73chevyman
73chevyman's Avatar
quick question what are the sizes of the gauges i want to do this myself
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 03-12-2009, 01:02 PM   #20
keith61760
keith61760's Avatar
The Equus Speeo and Tach are 3 3/8". The smaller ones are 2".
Old 03-12-2009, 09:17 PM   #21
bradf74
Keith.. I would like to see a pic of your mod. I will be going with that tach/speedo combo. thanks
Old 03-13-2009, 12:18 AM   #22
keith61760
keith61760's Avatar
This is the best I could do for pics of it. I didn't quite get the gauges lined up perfectly when I did the cut outs. When I finally get to putting everything back together I am going to tweak them a little and try to line them up better. For the turnsignals/bright/Park brake indicators I used LED's from Radio shack. I am going to move them up from below the dash panel as they are hard to see. Got out of work too late to take pics in the sun. Can try tomm if you would like.
Old 03-13-2009, 11:26 AM   #23
bradf74
That looks good. How did you make the extra bezel for the larger gauges to fit?
Old 03-13-2009, 07:15 PM   #24
keith61760
keith61760's Avatar
To make the bigger gauges fit, I used a piece of metal and cut it to fit into the stock housing. Then put those into the housing. The smaller gauges are mounted directly to the trim ring. Mine was metal but all of the others I have seen are plastic. I still need to make some adjustments to the smaller gauges so they are aligned. I built up a wire harness so I can easily disconnect if needed.
Old 03-13-2009, 09:03 PM   #25
tvblazer78
Low & Fast!
tvblazer78's Avatar
Looks good, I just about did that to mine that way..
tvblazer78 is offline   Reply With Quote
