Old 03-12-2003, 12:57 PM   #1
Purs
Got Big Block?
Purs's Avatar
"Steer" me right
is the steering shock stabilizer just a regular shock or what? I need to replace my stock one and don't know what to look for. Can anyone "steer" me in the right direction?
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 03-12-2003, 01:18 PM   #2
72K10
Pretty much any parts store should carry one. I got one from Autozone. Steering stabilizers appear to extend much further than a regular shock. They cost about the same as a single shock absorber.
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 03-12-2003, 01:58 PM   #3
Stout72
Not my good side.
Stout72's Avatar
Depending on the size of the tires you are running, you may need a dual setup. I've heard anything bigger than 33s should have a dual shock steering stabilizer.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 03-12-2003, 03:06 PM   #4
Purs
Got Big Block?
Purs's Avatar
33's is what I'm running now. I'm going to add a 2" lift pretty soon. Should I wait to put the steering stabilizer in then? What is involved with the install? thanks for the replies.
Old 03-12-2003, 03:37 PM   #5
Stout72
Not my good side.
Stout72's Avatar
You can put it in now if you want. A lift has no effect on the install. If you're getting any bump-steer, a stabilizer setup will dampen that out. I get a considerable amount of bump-steer with 35s, but I'm sure my stabilizer shocks have just about had it.
They're pretty easy to install, basically the setup is u-bolted to the tie rod and axle tube. Some axles have a pad welded to the tube to mount that end to, some tie rods are drilled for its respective end. Dual setups come in a parallel configuration, or an end-for-end configuration. The end-for-ends give you a little more ground clearance.
Shop the 'Net, the local 4Wheel Parts store, or else consult 4 Wheel & Offroad magazine, there's a ton of vendors that advertise in there.
00 Suburban LT
90 Camaro RS
Old 03-12-2003, 03:40 PM   #6
Purs
Got Big Block?
Purs's Avatar
thanks stout!
Old 03-12-2003, 06:34 PM   #7
Yukon Jack
Yukon Jack's Avatar
My 69 is fine with a single stabalizer running 35's. From what I understand a stabalizer is different from a shock - not sure what is different though.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-12-2003, 07:24 PM   #8
Jason71k10
ready for reassembly
Jason71k10's Avatar
i read on here that a s.s. is valved differently than than a shock. If it weren't then the s.s. would always be trying to steer you to the right because it would expand, wouldn't it??
i'm not sure, I only have 31's, so i'm not running one, but i plan to in the future. I'll probably just buy a s.s. and fab my own brackets.
Jason
Jason71k10 is offline   Reply With Quote
Old 03-12-2003, 08:09 PM   #9
Bill W
I like to keep things looking factory. So I don't go for the aftermarket bolt on/bracket stuff. Your pickup has a factory steering stab and when it gets worn out you can purchase another one that fits in the factory place for not much money. Its out of the way, does its job and doesn't detract from the factory look.
Bill 1978 4x4 Shortbed Scottsdale.
Bill W is offline   Reply With Quote
