Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-06-2009, 02:28 PM   #26
6600DURAMAX
6600DURAMAX's Avatar
Re: Part Time Pulling Truck Build
Well the frame and misc parts are getting powder put on them as we speak, will post plenty of pics when I get it home but for now I have another ?????.
I am gettting my leaf springs back from the powder coaters and need to find the plastic pieces to go between the springs to keeep them from running through the powder and rusting.
Any ideas??????
thanks guys
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 03-30-2009, 01:15 PM   #27
6600DURAMAX
SHE's BACK.....................
Polished Diff cover arrive on Tuesday
Tranny will go to get rebuilt this week
Oil Pump form motor will be here Tuesday so it can go back together
Old 03-30-2009, 01:17 PM   #28
6600DURAMAX
Oh ya almost forgot, picking up my 35x14.50x17 Pitbull Rockers tonight
Old 03-30-2009, 05:29 PM   #29
shakedown96
shakedown96's Avatar
I would consider a front axel anti wrap system like your rear bars aswell. to avoid breaking parts I have found that the straighter you can run your drive shafts the less they will break. droping the front or tieing it down usualy helps load tranfer to the rear resulting in a more ballanced ground pressure between front and rear.
shakedown96 is offline   Reply With Quote
Old 03-30-2009, 05:35 PM   #30
6600DURAMAX
I plan on running roughly 800lbs or so on the front end (will have to see what the final weight of the truck is). Probably will run both the 6500lb class and the 7500 lb class.
I did think about running a front traction bar but decided not to. Maybe I will wish I would have??
Old 03-30-2009, 05:43 PM   #31
shakedown96
I hope it don't hop on you and get expensive.
Old 03-30-2009, 09:34 PM   #32
6600DURAMAX
Well the wife says I've spent to much $ and it's way to "pretty" to tear up
Maybe I will listen to her and never hook it ...........
Old 03-30-2009, 10:44 PM   #33
AJs72K5
AJs72K5's Avatar
Those shock towers are really nice. Who made them?
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 03-31-2009, 08:00 AM   #34
6600DURAMAX
I designed them and had them cut out locally on a table. I think I have the file I can send you if you have someone that can cut them out for you. Be carful and make sure you mock them up with the inner fender as it should fit tight against it. Also on the driver side you have to position it to clear the steering shaft. Other than that they are simple and look better than a hoop in my opinion.
Old 03-31-2009, 10:07 PM   #35
AJs72K5
AJs72K5's Avatar
Will have to hold off for now...need to get the MPFI done. But, those are very nicely done for sure!
- AJ
Old 06-05-2009, 11:23 PM   #36
og350
og350's Avatar
any new updates?
og350 is offline   Reply With Quote
Old 06-10-2009, 06:09 AM   #37
vtblazer
vtblazer's Avatar
Is it the pics or are the front shocks inboarded a lot?
Any pics of the mounting set up on the axle?
Cool build, looking forward to seeing it pull.
vtblazer is offline   Reply With Quote
Old 06-10-2009, 07:48 AM   #38
6600DURAMAX
Sorry I have not been keeping up with this thread but I am having a hard enough time just getting this thing put back together. I dont have pics of it in its current state but I will post the ones I have.
Here are pics with the motor/trans/case sitting in it
Old 06-10-2009, 07:57 AM   #39
6600DURAMAX
As it sits in the garage today:
All the body is on just having a hard time aligning the passenger side door!! I can stick my fingers in the lower portion of the darn thing. Cant figure it out. Plus I need to shim the cab and bed to match the front clip.
Interior and all new wiring is done, just need to hook up the hot wires and make sure nothing melts.
Hydroboost is 95% complete, need to cut one more stainless steel return hose and install, then bleed the system.
Remote Transmission cooler is installed just need to build a rock shield for it since it is under the bed, and then finish hooking up the 6AN lines for it.
Bumpers can go on once I finish with the body panels.
We are close to having this thing back on the road just alot of smal details I want complete first.
THEN I still need to finish the front weight bumper, driveshaft loops and the rear bump stops before she can be hooked to the sled.
I will try and get some more pics posted within a week or so. I am suppose to be off all next week so maybe she will be ready to do a burnout soon!!!!!!!!
Old 06-10-2009, 05:01 PM   #40
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Question Re: Part Time Pulling Truck Build
Will this replace the oe bumper? if so you interested in parting with it?
Eturnit3 is offline   Reply With Quote
Old 06-10-2009, 06:23 PM   #41
og350
og350's Avatar
so what are you planning for driveshaft and u joint covers? i am starting to build some and dont have any good ideas.
Old 06-11-2009, 07:52 AM   #42
6600DURAMAX
Eturnit3 - The factory bumper will always be there, I have designed the weight bumper/bracket to hang below the factory bumper, so that when on the street it looks better.
The rear cover will be at the axle end only for now as that is the end that will break long before the transfer case end breaks. But for the rear I had Kurt at DIY4x4 cut me a flat plate that will bolt to the front flange bolts that surrond the pinion on a 14 bolt. I will then weld a 8'' piece of pipe around that. Use 4 studs and slide the gaurd over it. It is kind of hard to explain without pictures. I will try and take some pics once I get it going but that could be a couple of weeks. As far as the front goes again I am only worried about the axle end and the only thing I know to do there is drill some holes in the pinion flanges. Again without pics it is hard to describe. A good place to look is Competitiondiesel.com they have a whole section dedicated to driveshaft loops.
Old 06-25-2009, 04:07 PM   #43
SMiller
Strap the front axle to the frame as tight as you can, you will REALLY want the front end tight and low! I hope you don't have to much tire. Can't wait to see some updates. When I had my pulling truck my pulling hitch mounted in between the rear frame wells about 1ft from the rear of the truck, very high, had to cut a whole out of the bed to put the hook on. If you arn't running ladder bars you can use a chain and binder to chain the rear axle back to the pulling hitch to keep it from wrapping to hard, little things that work...
If you can't run blocks you will want a leaf pack that is so think and rock hard that nothing can squat it, the way it looks you will have the front end off the ground.
SMiller is offline   Reply With Quote
Old 02-01-2010, 02:50 PM   #44
Dudewith4x4
Momma Tried.
Dudewith4x4's Avatar
Hey dude. Im kinda going the same aproach as you but I am a noob. lol I wanna pull with mine when finished. For my wieght bumper I thought about designing some kinda grill guard that I can put tractor wieghts on.
Ross
1980 c10 4x4 project (Sold):http://67-72chevytrucks.com/vboard/s...d.php?t=377155
1999 F-150 4x4 (DD)
Saving up for a 64
17 and loving it.
Dudewith4x4 is offline   Reply With Quote
Old 02-01-2010, 05:00 PM   #45
6600DURAMAX
I have not been able to work on my weight bumper since the truck was completed but all the pieces are sitting on the garage floor waiting to be welded together. To get a good look at some real pulling truck weight bumpers go to this site http://www.competitiondiesel.com/for...read.php?t=881
Tractor weights are the way to go if you have them, I had a lead on some 3''x3'' solid steel bars that I had cut to 40'' for my weight. I think I have around 1200lbs worth
Old 02-01-2010, 05:02 PM   #46
6600DURAMAX
Guess I could post some pics of the truck completed !!!!!!!!!
Old 02-01-2010, 05:29 PM   #47
Dudewith4x4
Momma Tried.
Yeah we have a **** ton of them.
Take a look at my build some time if you wanna man.
Ross
1999 F-150 4x4 (DD)
Saving up for a 64
17 and loving it.
Old 02-01-2010, 05:41 PM   #48
6600DURAMAX
I am looking for 10-15 of the 60to70 lb weights if you have some you want to sell. Let me know
Old 02-01-2010, 05:42 PM   #49
Dudewith4x4
Momma Tried.
Lol Ill look. Everyone wants to buy our weights. lol
Ross
1999 F-150 4x4 (DD)
Saving up for a 64
17 and loving it.
Old 02-01-2010, 06:15 PM   #50
6600DURAMAX
some pics after Indy last year
