Old 03-08-2009, 03:07 AM   #1
Zoerb
Zoerb's Avatar
Transfer case mount......
Does this mount look correct (the square tubing is not attached to the frame rail, and i'm not sure what it's doing there)? The mount attaches to the transmission correctly, but I don't see anything to help support the transfer case.
What concerns me is the angle from the trans to the t-case.
Does anyone have a picture of the transfer case installed with the correct mounts?
Truck is an 86, Np208, 350/700R4
2017 Tahoe Premier - Daily
'99 Silverado 2500
Wife's whip- 2020 Equinox Premier
Zoerb is offline   Reply With Quote
Old 03-10-2009, 01:24 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Transfer case mount......
Looks right to me. My brother has a 87 K5 with the same setup. I'll look and confirm the angle and I'll take a few pics.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 03-10-2009, 08:59 AM   #3
haysonj
haysonj's Avatar
I have that same support on my 69 and it came out of a 80's truck the two spacers on the bolts in the middle should be on the outside one where the sq tube is and the other on the other side with four bolts holding the support to the frame.the 208 has a strait input shaft and mine with a T400 is strait from trans through the transfer case. There also should be a torque bar from the transfer case to the bell housing on the trans. I fabbed a bracket to the frame and mounted the transfer case to it with a neoprene bushing.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-17-2009, 07:17 AM   #4
edge
edge's Avatar
i have an 85, looks like the same POS corossmember, the angle is "to me" just what happens to them over time, and it also pulls the rubber mount in center apart in bending, loosens the bolts too over time. the sq i would say the PO wedged it in there to help prevent this from getting worse. (however it bends in middle not out the ends) the crossmeber is a weak design to me. wait to you hit something in the center of it offroading or get it hung on something it will bend it further down real easy. very weak, i'm replacing with an earlier type better crossection area. i'm assuming it is on the truck in avaitar...
edge is offline   Reply With Quote
