Old 03-12-2003, 11:24 PM   #1
70chevy
70chevy's Avatar
Question Drip rail question?
I started shaving my drip rails about 2"-3" at a time and was wondering about the gap being different around the upper half of the door. I have a picture also if someone could tell me if this is looking correct. If not what needs to be done different.
The gap is my big concern. What is everyone doing with this space?
[img]http://www.boomspeed.com/ksmith23/Shaveddriprail.jpg[\img]
Thanks,
Ken
Ken Smith
99 C5 Torch Red Coupe
85 Chevy Candy Apple
70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump,
70chevy is offline   Reply With Quote
Old 03-12-2003, 11:25 PM   #2
70chevy
70chevy's Avatar
Picture I think this time....
Ken Smith
Old 03-13-2003, 01:55 AM   #3
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
I don't understand your ? from your pics. Elaborate a little.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 03-13-2003, 02:05 AM   #4
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Here's a pic of the 68. This was my second drip shave, did the first one on my 72 but it got totaled
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 03-13-2003, 08:16 AM   #5
70chevy
70chevy's Avatar
The drip rail isn't just on the outside. When you remove the drip rail there is part of it that is spot welded on the inside of the door jamb.
After you remove that you will have a larger gap between the door and jamb. What do you do about the gap?
Here is another view, you can see where i have already welded the gap up but, between the weld and the ground part just to the left in the center is where the gap will be larger.
Hope this is a little easier to understand.
Ken Smith
Old 03-13-2003, 09:58 AM   #6
MellowYellow70
How about body filler or you could weld precut strips to fill in the gap and return to an equal distance, imo.
Do a call on efabman or some of the gurus in the paint/body section.
If patience is truely a virtue, Then I am so screwed
1970 Chevy SWB 331 sbc and all the goodies. Under resurection
2001 Vette
MellowYellow70 is offline   Reply With Quote
Old 03-13-2003, 10:36 AM   #7
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Yep that's what you have to do now. Cut a piece and weld it in so you can finish it out. I left that piece you took out with the spot welds. I welded it on the inside portion also then finished out with METAL TO METAL body filler. This is some pretty bad $hit, but it is costly.
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 03-13-2003, 12:37 PM   #8
70chevy
70chevy's Avatar
After I cut the first inch or so I seen rust behind the strip so I thought I may as well remove it to make sure I get all the rusted areas.
Its not really that bad but since the cab will be blasted might as will get to all areas.
Thanks for all the info, shouldn't be that big of a deal. If you take your time its not as difficult as I thought it was going to be.
Ken Smith
