Old 03-11-2009, 11:39 AM   #1
bentfab
bentfab's Avatar
Bent Custom and Performance Back-half
Here's a couple sneak peak shots of a back-half we are working on. Everything is designed in house. From what I see and have learned over the years is why take something that isn't broke and try to fix it. These mid 60's trucks have *****en rear suspensions. All you need to do is improve upon it. I've redesigned my own rails and suspension mounting points so you can have the proper look and ride. I took the factory trailing arms which I might add are cool looking to start with. I then reinforced modified and added some look. Let me know what you think? I will have more pics of completion in the next couple weeks.
bentfab is offline   Reply With Quote
Old 03-11-2009, 02:31 PM   #2
project 67 sub
project 67 sub's Avatar
Re: Bent Custom and Performance Back-half
nice... looks really good.
project 67 sub is offline   Reply With Quote
Old 03-11-2009, 03:21 PM   #3
joe231
joe231's Avatar
WOW!
your work blows me away!!!
are those stock arms reinforced or complete customs?
Love the sexy curves of the back half
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-11-2009, 05:57 PM   #4
68 short step
looks great.
68 short step is offline   Reply With Quote
Old 03-11-2009, 10:45 PM   #5
bentfab
bentfab's Avatar
Originally Posted by joe231 View Post
WOW!
Thanks very much
The rails are stock modified. I added the sides for some look.
Old 03-12-2009, 12:38 AM   #6
fixit-p
fixit-p's Avatar
Those are gonna look so good when mounted..I was already leaning towards trailing arms for my c20 conversion and this settles it. I've been considering fabing my own with a built in 2" drop and pinion correction for a 3" drop spring. Is the crossmember also stock modified.
fixit-p is offline   Reply With Quote
Old 03-12-2009, 12:42 AM   #7
OARNGESI
OARNGESI's Avatar
That looks like really good work
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-12-2009, 08:59 AM   #8
joe231
joe231's Avatar
cross-member looks to be a CPP piece......
CHEVY ONLY
Old 03-12-2009, 10:55 AM   #9
bentfab
bentfab's Avatar
Yes it is a CPP. But it wont look like one when were done. If there's enough demand for making these back half's we'll make something better. This is kind of a prototype/second version of my old truck.
Old 03-12-2009, 11:25 AM   #10
Hart_Rod
Hart_Rod's Avatar
In.
Hart_Rod is offline   Reply With Quote
Old 03-12-2009, 12:55 PM   #11
fixit-p
fixit-p's Avatar
What dimension did you end up with after boxing and capping the trailing arms W x H
Old 03-12-2009, 03:43 PM   #12
bentfab
bentfab's Avatar
The dimensions are still stock hole and mounting wise. The top and bottom plates are about 120thou. and the back was just capped. So hight is probable just about a 1/4 more than stock.
Old 03-12-2009, 07:21 PM   #13
Dinos63
chevy only
Dinos63's Avatar
Nice very nice
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 03-12-2009, 09:41 PM   #14
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
Looks great!! What is the wall thickness of that 2X4 tubing? Also what do you use to bend it?
p8ntballer1911 is offline   Reply With Quote
Old 03-12-2009, 11:00 PM   #15
SCOTI
SCOTI's Avatar
I believe they're just 'capped' or boxed factory trailing arms.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-12-2009, 11:02 PM   #16
bentfab
bentfab's Avatar
The frame started out as .125 flat sheet. It's alittle labor intense but it's four sides welded together and then radiused along the edges. It's the only way in my opinion to do a complete backhalf. It's clean simple and all the specifications and design are the way I want it . No guess work. There is still going to be more hand made peaces and I'm not sure if I want to lay the shocks parallel to the ground.
Old 03-12-2009, 11:21 PM   #17
Musclerodz
Nice to see you over here. Looks sick. You would give these guys a heart attack if you show them the good stuff.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 03-13-2009, 12:04 AM   #18
SCOTI
SCOTI's Avatar
Doh . .... I thought he was referring to the arms .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-13-2009, 01:56 AM   #19
Twisted Minis
Twisted Minis's Avatar
I want a heart attack.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 03-13-2009, 03:28 AM   #20
project 67 sub
me too lol.
Old 03-13-2009, 08:40 AM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
Oooh, you have more pics like this? You know we want more.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-13-2009, 11:14 AM   #22
fixit-p
fixit-p's Avatar
Yeah...Dont be a Fab tease.
Old 03-13-2009, 09:51 PM   #23
Musclerodz
Since Mark has not shown the way, here ya go. Besides a car builder, he is a plumbing specialist.
http://www.bentcustomandperformance.com/
Mike Redpath
Old 03-13-2009, 10:04 PM   #24
N2TRUX
Happy to be here
N2TRUX's Avatar
WOW! Very impressive...
Articles-
"Refining Sierra"
Old 03-13-2009, 10:31 PM   #25
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Wow!!!!!!!!!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
