Old 03-11-2009, 08:55 PM   #1
project 67 sub
project 67 sub's Avatar
adjustable panhard bar?
i plan on making my own adjustable panhard bar, but need to know the length from this point to this piont. if someone that has one can measure it for me it would be very appreciated.
below is an early classic bar that i used as a pic referance so you know what i am talking about
project 67 sub is offline   Reply With Quote
Old 03-11-2009, 09:07 PM   #2
ruggs
Re: adjustable panhard bar?
Rather than take another persons design maybe, pull centerline of your truck and then you will find the magical number.
ruggs is offline   Reply With Quote
Old 03-11-2009, 09:14 PM   #3
Skirkpat
Skirkpat's Avatar
I don't think Early classics "Designed the panhard bar" Unfortunately they took it from someone, who took it from someone, who...well you get the point.
Skirkpat is offline   Reply With Quote
Old 03-11-2009, 09:16 PM   #4
project 67 sub
ruggs;Rather than take another persons design maybe, pull centerline of your truck and then you will find the magical number
because i cant get to my truck right now and it doesnt currently have a panhard bar. plus i am not copying someone elses exactly, my mount brackets are going to be different cuz i already have mounting tabs, 3" lowering blocks and longer u bolts. i just need a measurement so i can make the bar itself
Old 03-11-2009, 09:39 PM   #5
Andy4639
Old member
Andy4639's Avatar
Easy guy's,
The adjustable bar is not what I call adjustable, well not once you install it anyway. I have the one pictured and it's great but the word adjustable is loosley fitting for it. The only way you can adjust it is to take it off.
I can get a measurment in the morning for you, I'm at work tonight but can grab it when I get home.
project 67 sub,
I hope you make yours a real adjustable one.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-11-2009, 11:13 PM   #6
project 67 sub
thanks Andy4639. yah i dont know yet if im going to make it a real adjustable one yet but i might. right know its static drop about 9" in the rear, and the stock panhard bar was running uphill and pulling the diff. to the drivers side so i gotta make a new one cuz im on a very limited budget right now and cant buy one, but i already have the tube to build it, and the 1/4" plate for the tabs.
Originally Posted by Andy4639 View Post
Easy guy's,
project 67 sub,
Old 03-12-2009, 12:08 AM   #7
Andy4639
Old member
Andy4639's Avatar
I'll grab it in the morning. I 'm off tomorrow night so I'll be up most of the day.
Old 03-12-2009, 12:14 AM   #8
project 67 sub
ok cool
Old 03-12-2009, 12:43 AM   #9
Andy4639
Old member
Andy4639's Avatar
It not that big of a deal I guess it's just when I saw the adjustable I thought they meant while installed. Once you put it in you shouldn't ever need to move it I guess.
Old 03-12-2009, 01:35 AM   #10
Andy4639
Old member
Andy4639's Avatar
I just measured mine 33 1/2 ".
Old 03-12-2009, 10:05 AM   #11
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Do stock come in different sizes? Mine bar is like 24" center to center of bolt hole.
sneakysnake is offline   Reply With Quote
Old 03-12-2009, 10:08 AM   #12
sneakysnake
I just realized you are relocating the mounting points??
Old 03-12-2009, 10:11 AM   #13
mycool72
mycool72's Avatar
There's no point in making it "adjustable" If you're going to make one just set the truck at your ride level and put one side to the rear end and the other side to the frame and wha la!
Moving the stock plate helps with a large drop, the rod will bottom out unless you move it. I moved mine to the inside of the rail but i have seen them on top of the rails as well.
mycool72 is offline   Reply With Quote
Old 03-12-2009, 10:44 AM   #14
Andy4639
Old member
Andy4639's Avatar
Here is mine installed.
Old 03-12-2009, 12:22 PM   #15
project 67 sub
thanks for the measurement Andy4639
Old 03-12-2009, 12:25 PM   #16
project 67 sub
thats how im going to mount mine, but but with my tabs welded to my 3x3x.250 wall steel lowering block
Old 03-12-2009, 09:58 PM   #17
ruggs
project 67 sub,
I didn't mean to upset anyone and wasn't aware that you weren't near your truck. Just intended to say that if you measured centerline of the truck and know the travel of the rear end you can find the measurement. Sorry if I came across wrong....ruggs
Old 03-13-2009, 03:51 AM   #18
project 67 sub
no problem bro. i dont get butt hurt from stuff like that lol. so no biggie. im not trippin.
Originally Posted by ruggs View Post
project 67 sub,
Old 03-13-2009, 03:53 AM   #19
project 67 sub
does any body know off hand what size diameter stud that is on the diff. that the panhard bar bolts to?
Old 03-13-2009, 02:12 PM   #20
project 67 sub
^^^^bump for possible answers
Old 03-14-2009, 04:18 PM   #21
Andy4639
Old member
Andy4639's Avatar
Looks like 5/8" bolt to me. I tried getting it out, and it ant budghing. I will try again later to remove it. Didn't have a lot of time this afternoon.
Old 03-14-2009, 06:43 PM   #22
project 67 sub
thanks Andy4639
3/8" sounds kind of small....oh I just read the tape and it looks more like it says 5/8" or 3/4"
Old 03-14-2009, 09:42 PM   #23
Andy4639
Old member
Andy4639's Avatar
Yep more like 5/8 I must of fat fingered the keys. I was asleep when I measured it too!
Old 03-14-2009, 11:16 PM   #24
project 67 sub
haha yah no biggie bro i appreciate it
Old 03-15-2009, 12:28 AM   #25
Andy4639
Old member
Andy4639's Avatar
No problem I think I got a wrench to get it out with tomorrow. I had plan to get it out when I did the rear end work and forgot about it until I got under there to take the measurements for ya! Thanks for reminding me.
