Old 03-12-2009, 01:26 AM   #1
tthornt
tthornt's Avatar
83 c10 steering column replacement
All, can somone please prove me an how to replace a steering cloumn. i've never had to repalce one. any and all help would be greatly appreciated.
Thx
TTHORNT
Country; LIKE A ROCK
All that I am, I owe
62SWB-STEP
83SWB
86LWB
tthornt is offline   Reply With Quote
Old 03-12-2009, 04:26 AM   #2
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: 83 c10 steering column replacement
1- Remove the small lower dash bezel (under the column) and metal cover that's under it.
2- Unplug the long flat plug that's on the shaft behind the cover you just removed.
3- Unplug the ignition switch (midway down) and neutral safty switch (by the firewall)
4- Remove the shaft bolt above the rubber damper. (outside/engine bay)
5- Remove the shift linkage and the two bolts that clamp the coulmn to the firewall. (outside/engine bay)
6- Remove the bolts from the firewall cover (where the column goes through)
and pull that off (one side will come appart)
7- If your shift inacator wire/cable is still hooked up you should remove that.
8- Now remove the two nuts that are holding the column (behind where the cover was) and it should be ready to come out.
Hope that helps!
heavychevy79 is offline   Reply With Quote
Old 03-13-2009, 11:44 AM   #3
tthornt
tthornt's Avatar
Thx, i really appreciate your help on this.
tthornt
62SWB-STEP
83SWB
86LWB
