Old 03-12-2009, 09:40 PM   #76
JML55
JML55's Avatar
Re: 55 2nd serie GMC
Not doing to much this past couple a weeks. Next is the rear diff work i will be replacing the axle bearings, seals and finish welding the four link brackets. I have been trying to ID this diff for a while now but i still have no idea what it came out off. It came with the truck when i purchased it so i'm trying to make it work for my build. It has 2.73 gears in it, date code is H268 which should be Aug 26 1968. How are those gears going to work out with the 5.3 and 4l60e??
JML55 is offline   Reply With Quote
Old 03-13-2009, 07:56 AM   #77
b00sted
b00sted's Avatar
That rearend looks very wide... How wide is it from backing plate to backing plate?
The 5.3 and 4l60e will like a 3:73 allot better... IMO it is way to high of a gear...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 03-13-2009, 08:33 AM   #78
bensimmons_05
bensimmons_05's Avatar
Ive definately never seen a diff. cover like that. Looks like you could paint the top brown.. put some googly eyes and a mouth on it, and your differential is turned into a dude with a chilli bowl!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 03-13-2009, 12:37 PM   #79
1-ton of fun
polishing a turd
1-ton of fun's Avatar
it is an 8.2" gm rear. not too strong, but could be ok, depending on your hp expectations.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 03-13-2009, 12:49 PM   #80
OrrieG
OrrieG's Avatar
2.73 with od trans is great for cruising but you will spend a lot of time in 2nd and 3rd in town. Nothing off the line. My 64 Chevelle has 3.08, I upgraded to a TH350 from PG to get lower first gear and its still a dog in town. 3.73 with OD trans works well.
Old 03-13-2009, 05:56 PM   #81
JML55
JML55's Avatar
Thanks for the info guys, i'm running stock 5.3 vortec /4l60E. I'm realy not building a race car here, i just want a nice highway cruiser easy on gas. i live out of town and drive 60 miles every day to go to work.
Old 03-13-2009, 08:23 PM   #82
b00sted
b00sted's Avatar
then you will want the 3:73.. If you keep the stockers you are going to have to shove your foot through the floorboard to pass someon..
Also something to keep in mind is that the weight of the vehicle plays a roll in gear ratio's along with HP...
A lighter vehicle needs less gear... Also it has always been a rule for performace minded vehicles that 2900 lbs is max weight of a car with a glide...
Old 04-19-2009, 12:14 AM   #83
JML55
JML55's Avatar
Here the latest work on engine and tranny mounts.
A few months back I had the engine set up with late model mounts with clamp shell type bracket but i didn't like the way the engine sat. It was too low I had issues with tie rod ends touching the pan, p/steering pulley touching the steering box, so i decided to start all over. Fabricated the engine bracket as per the schematic i got from LS tech, bought new early style energy suspension mounts and solid frame bracket for early camaro.
Name:  engine mounts 006.jpg
Name:  engine mounts 007.jpg
I'm much happier with this set up now. Looks a lot more professional and it raised the engine about 3/4". I now have good clearance with the steering box and the tie rod ends.
Name:  engine mounts 001.jpg
Name:  engine mounts 002.jpg
Name:  engine mounts 003.jpg
Old 04-19-2009, 12:20 AM   #84
JML55
JML55's Avatar
Here the tranny crossmember. I made 1 1/2" spacer to be able to have about 4 degres of tilt on the engine.
Name:  engine mounts 004.jpg
Energy suspension mount here also, the factory rubber mount was way too flexible.
Name:  engine mounts 005.jpg
Old 04-19-2009, 01:38 AM   #85
71'tahoe
71'tahoe's Avatar
I like those mounts better also You say you got alot of your info from LSTECH.COM? I am a member on LS1TECH.com....just curious of they were the same site...Trucks is looking good!
71'tahoe is offline   Reply With Quote
Old 04-19-2009, 07:52 AM   #86
JML55
JML55's Avatar
Yes, I'm a member there also. Just a typo.
Old 04-28-2009, 11:49 PM   #87
northerngmc
northerngmc's Avatar
Originally Posted by JML55 View Post
Ha Ha !!!! These next pictures were taken Nov 07, my place, there is now twice has much snow.
I install the panard bar as per the instruction that came with the kit. My only concern is that the diff bracket is very close to the floor board. I may not be able to lower the suspension as much as i would like if i keep the original floor board.
Real nice truck, but I have to ask about the tractor with the loader, is that a W6?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 04-28-2009, 11:56 PM   #88
northerngmc
Picture did not come with the reply....
Blaine
Old 04-29-2009, 07:01 AM   #89
JML55
JML55's Avatar
1957 international 650, diesel. Looks like W6 but a little younger.
Old 05-03-2009, 11:19 PM   #90
JML55
JML55's Avatar
Here is the latest, working on the tailgate linkage kit I got from Mar-K last week. You got to be very precise in all the measurements and cuts. Tolerances are very tight but it was very simple to install.
Name:  tail gate 001.jpg
Name:  tail gate 002.jpg
Name:  tail gate 003.jpg
Name:  tail gate 004.jpg
Last picture is the new diff i got today, 2005 Blazer 4x4 discs brake and 3:73 gears. It a little narrow for my liking but i may use a different offset for the back.
Name:  tail gate 005.jpg
Old 05-04-2009, 12:14 AM   #91
GRIMSS
GRIMSS's Avatar
Your project is coming around nice. I need to find one of those rear ends.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 05-04-2009, 07:30 AM   #92
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
What's the width of the 4X4 rear? Thanks!
ChuckDriver is offline   Reply With Quote
Old 05-04-2009, 07:34 AM   #93
GRIMSS
GRIMSS's Avatar
The blazer 4x4's are 59" hub to hub.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-04-2009, 03:09 PM   #94
ChuckDriver
Got it! Thanks GRIMSS!!
Old 05-04-2009, 07:15 PM   #95
JML55
JML55's Avatar
I was actually looking for a ZR2 rear diff. I read somewhere that there even wider then the regular 4x4 . Do anyone know how wide is a ZR2 diff.
Old 05-04-2009, 07:59 PM   #96
GRIMSS
GRIMSS's Avatar
I have 63" writen down for the ZR2 but don't know where I found it.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-18-2009, 03:16 PM   #97
JML55
JML55's Avatar
What wheel should i use? front or rear one
Old 05-18-2009, 03:47 PM   #98
JML55
JML55's Avatar
Here is the new rear end muck up. I don't like where the caliper sit, it touch's the edge of the box side when the suspension is all the way down.
Old 05-18-2009, 03:59 PM   #99
britnjc
britnjc's Avatar
I would go with an old camaro rally wheel or something along those line. I just like the look of the old stock steelies
britnjc is offline   Reply With Quote
Old 05-18-2009, 06:41 PM   #100
57ToyBox
57ToyBox's Avatar
Nice progress JML
The calipers look good.
I like the front wheels, but then I like anything that shines
BTW nice shop
57ToyBox is offline   Reply With Quote
