03-13-2009, 09:03 AM | #26 | |||||||
Hollister, CA.
Re: HOW TO: Split the brake lines (many have asked)
thanks !!! Quote:
Sorry man...I caught this nasty flu virus (that has gone thru my whole family and then some)...so I haven't been on here for a few days. Thanks Captain....yes you should bench-bleed them. It amazing how much air is trapped in a new master.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
03-15-2009, 08:26 PM | #27 |
I just got the drum/drum boster set off a wrecked truck. Going to put it on and get it working first. Once thats done would i order the same master but for a p/b impala to split the lines??
There is no kragens near me but there is a oreilly's are they the same because they come up on the same web page?? Last edited by apachedaddy; 03-15-2009 at 09:10 PM. Reason: add on |
03-15-2009, 08:36 PM | #28 |
just a reminder to guys bending there own lines just remember if you have to flare please use double flares. i know its common sense please dont get offend.
03-15-2009, 10:21 PM | #29 |
i just wanted to add..................the 67-up truck masters work also, they can be had in drum/drum or disc/drum for under $30 too.
CHEVY ONLY |
03-16-2009, 04:41 AM | #30 |
Good stuff John...thanks for sharing.
03-16-2009, 09:48 AM | #31 | |
Hollister, CA.
Your Welcome !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-16-2009 at 09:49 AM. |
03-16-2009, 09:51 AM | #32 | |
Hollister, CA.
Yeap...that is corrrect. I went with an Impala, only because I had one sitting in the shop at the time for comparison. Also, a '69 Vette will also be a dirrect bolt-up for a disc/disc !! Funny, how do I know about that ??
03-16-2009, 10:08 AM | #33 | |
PIMPING RIDES
so chiefrocka if you are running disc /disc then you can use an impala or corvette master ,what year impala ?and will the master mount to a truck booster
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
03-23-2009, 10:24 PM | #34 |
Can some one explain what had to be done to the original push rod. I gathered all the parts to do this but dont want to break down the system until I know for sure what is involved in making the master cylinder work correctly. Thanks
03-23-2009, 11:20 PM | #35 |
Hollister, CA.
Sorry I haven't had a chance to finish this topic up, and make it a sticky....I haven't been on in a while. My pops is in the ICU and not doing so good.
If I remember correctly, all I had to do was loosen the jam-nut and extend slightly to achieve a slight endplay. Additional pics will follow shorty, with a parts list, as with some editing and then it get STUCK !!
03-24-2009, 12:25 AM | #36 |
I hope your pop is doing ok
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
03-24-2009, 12:50 AM | #37 |
60-66 Nut
X2.....I'll keep him in my prayers.
03-31-2009, 01:50 AM | #38 |
PIMPING RIDES
you said a 69 vette could be used for disc/disc ,then what booster works good.
04-12-2009, 12:51 PM | #39 |
Why does it taste purple?
I just bought a new MC to do this and would love to know which fittings I will need to achieve this swap. I don't wanna start until I got all parts in hand
Hello, my name is John and I'm a truckaholic |
05-10-2009, 08:56 PM | #40 |
ditto on the fittings list! I'd like to have it all ready to go so I can put it together in one evening.
No need to do any type of proportioning or metering valve to give the fronts more fluid in a drum/drum setup??????
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc |
05-10-2009, 10:42 PM | #41 |
Schlongbed MEMBER (heh)#15
I bench bleed my MC's by bolting it up, filling the reservoir and running a line from the port to the reservoir and pumping it. I never understood using a vise, etc. Thoughts?
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
05-11-2009, 08:07 AM | #42 | |
Hollister, CA.
Sorry, I'll get the fitting list soon... Works the same way....on a vise you can watch it closely thats all.
05-11-2009, 12:40 PM | #43 |
I always use the "in car" method. Has worked fine for me. Just install the plugs that come with the master and pump the pedal making sure not to move the piston more than 1 inch. I've also done it by hand holding the master in one hand and using a phillips screwdriver to pump the piston. Actually easier than it sounds
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
05-12-2009, 10:13 PM | #44 |
Thought I should add that on my 1962 GMC with the Dana 44 rear end, where the front 1/4" line tees off to the rear, my line to the rear is a 3/16" line. I wasn't sure if it was the same thread on the 3/16" line as the 1/4" inverted flare fittings (possible, didn't get to check), but I picked up a 3/16" adapter bushing in addition to the two other adapter bushings for the masters.
One was a 5/16" to 1/4" adapter, and the other one was 9/16"-18 to 1/4" I think. This fit my new remanufactured 1967 Chevy/GMC truck 1-1/8" bore drum/drum master cylinder. Got one piece of 60" line as I think I read someone else saying they needed about 51", and then I got a second piece 40" long to replace the line from the old master down to the first tee by the left front wheel. This piece will need to be longer on mine at least, since my 62 manual trans master has the lines out the bottom. The lines came double flared on both ends with the 1/4" inverted flare fittings already on. Advanced Auto Parts and Car Quest both had drawers full of these adapters, so it makes it pretty simple. Take your master with you and bush it down to 1/4". what I got: *60" of 1/4" line w/two inverted flare 1/4" fittings (for new rear line) *40" of 1/4" line w/two inverted flare 1/4" fittings (for front line, from new location on side of new master to tee at left front junction - might make do with a 30") *1/4" inv. flare coupling or union *1/4" plug *5/16" tube x 1/4" tube adapter bushing for master rear line (check your master) *9/16"-18 thread to 1/4" tube adapter bushing for master front line (check your master) DORMAN Part # M66787 More Info {First Stop #18008616, 3912128, 3941939, 5458531, 5458905} w/Power Brakes; Bore = 1-1/8"; RWD; Bendix; Exc. 11000 Lb Rear Axle$50.79 On the bushing sizes, I believe the thread sizes in the master are 9/16"x18 and 1/2"x20, but I listed the way Advance Auto Parts has them on my receipt. Also it should be noted that I am replacing a 1-1/8" bore master with a 1-1/8" bore master. I am adding a power booster (the old style that uses these deep bore masters same as a manual master's bore). I read in one article that said if you are switching over to power, you can get away with running one size larger master cylinder bore diameter. So I could have ran 1-1/4", but I hope to reuse this master minus the front residual valve for swapping to power discs, which would have used a 1-1/8" bore power brake master. Did I confuse you yet? I'm also dealing with a 60-62, so I have to get rid of my stock clutch/brake combo master and install a separate clutch master in the stock location, and using a power booster and custom made booster bracket to give me the room to run the clutch master in the stock clutch master location. See my other recent thread on this topic. I have not fit all this up yet, but based on Cheif's writeup, I think all of this is correct.
08-15-2009, 02:33 PM | #45 |
John you did have to drill new holes for the master right?
08-15-2009, 02:44 PM | #46 |
Hollister, CA.
No, not at all...it bolted right up.
Course, thats cause us 63 and up guys are special !
08-25-2009, 09:11 PM | #47 |
1961 crewcab
2 questions..
could Isee a pic of your tubing bender? not the belly the actual bender. and, does this kind of system need a proportioning valve? |
08-26-2009, 09:15 AM | #48 |
Hollister, CA.
It looks like this one....I also have the Matco double flaring kit.
- - Using a drum/drum master (two port Impala) you do not need a prop valve. - -
10-02-2009, 07:16 AM | #49 |
Hi Chief, Great write up. I am currently doing this on my '64. Got some questions. Did your old master have a 1" bore? What about the new one? My '64 is 1". The master at O'reilly's for a '70 Impala, drum/drum, no power, was 1 1/8. The master with a 1" bore was listed for discs with power. I believe I have read on other posts that using 1 1/8" master will make the brakes feel spongy. Do I have that right? Is the 1" bore the one to go with? I wonder if the parts store has it listed wrong? Thanks in advance for any help from anyone that can.
Eugene
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
10-02-2009, 08:50 AM | #50 |
Hollister, CA.
Not exactly sure, I'd have to research that.
I went with one from a '67 Impala. At the time, my buddys 67 Impala was in my shop, so I compared them. The brakes on the black truck worked great...full pressure and never spongy. My new truck will recieve the same treatment, although this one will get 6-lugs discs.
