Old 03-13-2003, 04:38 PM   #1
PHOENIX
Wink Wing Window Vibration (from sterio) ?
I guess Im pretty lucky because the only things that make noise (rattle) when the sterio is pumping is the wing window (driver only, atleast that I can hear ) and the door windows. The door windows are not an issue because I need new channel all the wa around except for the very bottom. I kow this will fix that problem.
I notice that the little pin in the wing window (upper pin/pivot point) is what is causing this rattle sound. If I put my finger on the pin, ever so slightly, the rattle stops. Anyone else had this problem? What can I do to fix this problem? Ohh yeah, it only does it when the wing window is open, I dont seem to notice it when its closed.
thanks!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 03-13-2003, 06:03 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I think they sell replacement rivets at LMC, so the dealer probably has them as well.
Can you tighten the rivet up with a ball peen hammer? Watch the glass!
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-13-2003, 06:17 PM   #3
PHOENIX
Do you think its loose and thats why is rattles?
I would think it would have to have some play to allow it to pivot.
It doesnt seem loose, and when I push it with my finger it doesnt move, it just stops rattling. im going to look at it better tonight and see if it looks loose or anything compared to the other side.
Old 03-13-2003, 07:59 PM   #4
apstguy
LED King
apstguy's Avatar
Uhhhh.... simple. Don't open the wing window!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 03-13-2003, 09:02 PM   #5
Slonaker
Slonaker's Avatar
I just assumed it was loose because you said it rattled...
Slonaker
Stock '01 Silverado
Old 03-13-2003, 10:05 PM   #6
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
ya i never open mine, my window rattles though...i just grabbed a scrap piece of window channel thati had lyin around and stuffed it in there but i think thats wore out now so i need to redo it
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
Old 03-13-2003, 10:50 PM   #7
84Stepper
84Stepper's Avatar
Rattling sucks!! My door rattles all of the time and I was wondering if anyone has used that spray on sound deadner? If so does the stuff work? Since I have my door panels off I was thinking about spraying that stuff all over to stop Rattling.
84 Chevy Stepside, 350, TH350, 268h
Comp cam, Hooker headers, MSD
Pro Billet, Edelbrock Performer manifold
and 1604 carb, 40 Series Flowmasters
dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi
84Stepper is offline   Reply With Quote
Old 03-14-2003, 01:24 PM   #8
PHOENIX
84stepper Im sure it would help, but do you know whats actually rattling? Windows are the most common. New seals all around the windows helps a ton!
So nobody has any ideas other then, dont open it
Did you forget that its hot here? The wing is like a life saver
Old 03-14-2003, 03:41 PM   #9
BigRed
You can buy new seals and rivets(pins) for those wing windows. They make a tool that you can also buy (cheap) to replace the rivet. I would replace that pin and see if that helps you out. If not, you may just need a new vent window assembly. It's probably just worn out.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-14-2003, 08:52 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I replaced all the window channels, door seals and modified the vent windows. No wind noise or vibratios. Most of my system stays in side the cab. Ever see a windshield vibrate.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-15-2003, 05:11 AM   #11
twistedmetal
Take it to the limit
twistedmetal's Avatar
Use 2 hammers ,one on each side of the rivit,give gentle taps till its mushroomed enough.
"If Fall Guy only knew how many trucks i wrecked,He'd be proud"
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
