Need part #'s-71/72,351 GMC,V/6
My 351 runs o.k.but the plugs are so old and rusty that I can't read the A/C part numbers on them.
My local NAPA is out of business and the other stores don't even show a 305 or 351. So,if anyone has the number for A/C plugs for a 351? I think it's a 71 or 72 and is out of a big truck.It has pcv system. Thanks,Mike. ![]() |
Re: Need part #'s-71/72,351 GMC,V/6
I dont know off hand but ill look in the book when i get to work tommorow afternoon.
found some info on classic parts forum
i found some info on that 305e (and the 351e v-6) compression ratio was 7.75 to 1 compression pressure was 125 p.s.i. spark plugs ac,c45ns plug gap is .035" plug torque is 25 ft. lbs. point gap is new-.019 old-.016 dwell 31-34 degrees arm spring tension 19-23 oz. firing order 1-6-5-4-3-2 timing without a.i.r. 7 1/2 degrees budc with a.i.r. (mech. trans.) 2 1/2 degrees audc with a.i.r. (auto. trans.) 7 1/2 degrees budc valve lash (hot) intake valves 0.012" exhaust valve 0.018" engine idle speed (rpm) without a.i.r. 500-550 with a.i.r. mech, trans. 650 with a.i.r. auto trans. 550 bolt torque information (ft-lbs) cylinder haed bolts 60-65 exhaust manifold bolts 15-20 intake manifold bolts 20-25 water outlet manifold bolts 20-25 rocker arm shaft bracket bolts 20-25 crankshaft hub bolts 180-200 Last edited by eseaton; 03-13-2009 at 10:43 PM. |
Eseaton,thanks for the information!
Mine is actually a 351-C,but the plugs will still work I'm sure. The engine is sitting on an engine stand,and I like to run it ever so often. Again,thanks,especially for the quick response1 Mike. |
100%chevy
Not a prob i have gotten so much help here that all i can do is try to help the next person in line. eric |
