Old 03-15-2009, 06:47 PM   #351
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 03-16-2009, 11:42 PM   #352
68 short step
bit more progress, i got the door fitting the best it could.....the gaps sucked (aftermarket door), expecially around the window frame.....it was too tight on the upper aft part of the window opening, then it tappered to about a 1/4" gap in the middle, and then went to about a 1/32" at the upper front.......what i had to do was cut the door at the front door piller, then remove 1/8" of material, pull the front frame back....that took care of the front piller gap....on the rest of the window frame i pushed the rear of the window frame forward, then shaves off about 1/16" to get the gaps good......
68 short step is offline   Reply With Quote
Old 03-17-2009, 05:36 AM   #353
mike nutt
69fatmotor
mike nutt's Avatar
don ,
the truck is looking great . are you going to weld the seem across the back of the roof ? what's the color gonna be ? well , keep up the great work , can't wait to see it finished. i'm sure the owner is gonna love it !!!!
mike nutt is offline   Reply With Quote
Old 03-29-2009, 08:29 PM   #354
68 short step
Originally Posted by mike nutt View Post
don ,
ya we're gonna do a little somethin somethin to the rear roof seam.....
as for the color, its still to be determend....
Old 03-29-2009, 08:38 PM   #355
68 short step
here is a bit of an update....
got the rear step notch installed, (the old c-notch wasnt doing it for us) so with the step notch we were able to lower it about 2" more..... here is some pics, the shocks will be added shortly, when the bridge goes in..... also keep in mind that the tires on there now (rear) are for rollers only, they are 31"....
Old 03-29-2009, 08:39 PM   #356
68 short step
Old 03-29-2009, 09:50 PM   #357
Hart_Rod
Hart_Rod's Avatar
That's starting to look like a truck!!!!! When's the projected completion date?
Hart_Rod is offline   Reply With Quote
Old 05-03-2009, 07:05 PM   #358
68 short step
got a bit of an update.....
im back on the dash/center console....i got the side peices made......the center console is kinda challenging (because i wanted to make it out of 1 peice), so instead of making it out of 1 peice, its gonna be 4 peices welded together....here are the side peices, they have a rolled top (kinda see this in the pics), and also im gonna make a inner structure to support the weight of our electronics, arm rest, and just general wear and tear it'll receive.....
also here is the side profile of how the truck sits now with 30" tires rear and 27.5" tires on the front (both on 15" wheels).......
Old 05-03-2009, 07:07 PM   #359
68 short step
Old 05-03-2009, 07:16 PM   #360
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I take it the garage was getting too smalll...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-03-2009, 07:31 PM   #361
killer71
killer71's Avatar
need more photos of the tool ben lol...thought it was goin in the kitchen?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 05-03-2009, 07:58 PM   #362
68 short step
yelp, i had to make a move, when i started takeing up family members garage space
ill have to get some....morgan said "nuh uhhhhh"
the specs are 72" wide 30" deep and 45" tall.....its a big-unnn
Old 05-03-2009, 08:53 PM   #363
SCOTI
SCOTI's Avatar
Hey..... Those bedsides look might familiar .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-04-2009, 02:37 AM   #364
kyull67
kyull67's Avatar
That's some nice work!
kyull67 is offline   Reply With Quote
Old 05-04-2009, 07:06 AM   #365
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-06-2009, 06:57 PM   #366
teezyboi817
how much would that dash center console run me if u made me one similar to it
1968 CHEVY C10
THE NEVER ENDING PROJECT
teezyboi817 is offline   Reply With Quote
Old 05-08-2009, 06:43 PM   #367
68 short step
let me finish up with this one, and ill let ya know
Old 05-08-2009, 10:48 PM   #368
nuke1
nuke1's Avatar
I am so jealous of your ride height, mine will be 2 inches taller than i had hoped for, guess bags will come into play later, btw that console is just plain Sexy.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 05-10-2009, 09:57 AM   #369
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
Originally Posted by 68 short step View Post
Need more room
72 SHORTBED 7.0 is offline   Reply With Quote
Old 05-10-2009, 10:37 AM   #370
68 short step
Originally Posted by 72 SHORTBED 7.0 View Post
Need more room
i know...
Old 05-10-2009, 10:46 AM   #371
Rokcrln
Rokcrln's Avatar
You will always need more room. We sold our old house to buy this one with a 1200 sq. ft shop, plenty of parking and a 2 story out building and now we are out of space. Luckily I am zoned commercial so I can put a second story on the shop for almost 2400 sq. ft. Not bad for being right down town. Next stop will be 5+ acres!
Truck is looking great by the way. I like the dash you have designed. I should have my Lazze English wheel real soon so I can start playing as well.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-10-2009, 10:47 AM   #372
68 short step
got the center console made....the front peices were the last peices to be made, so i made a cardboard templete, transfered it to metal, cut and fit, added a stiffner for some rigitity, then welded together. .....ill add some stiffners that connect the two sides, when the dash comes back out.... here are the pics (the 3rd one looks like some mid-evil deheading device)
Old 05-10-2009, 10:50 AM   #373
68 short step
and the other side
Old 05-10-2009, 10:53 AM   #374
68 short step
and it fitted in,
Old 05-10-2009, 12:03 PM   #375
n2billet
Village Idiot....
n2billet's Avatar
Looks great! Are you going to make any provisions for carpet or leather to go under the console or are you going to bind the carpet at the edge?....sorry I'm in interior mode right now and it looks like the console fits nice and flush with the floor...
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
