Old 03-13-2009, 09:03 AM   #26
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: HOW TO: Split the brake lines (many have asked)
Originally Posted by Barebones66 View Post
Excellent thread
Very helpful
thanks !!!
Originally Posted by kizer View Post
Ok, I'm assuming your using the port on the master farthest towards the grill as your front connection and the one closest to your firewall as your rear wheels right or am I backwards or are you going to tell me it doesn't matter?
Yes...thats correct....I couldn't get it to bleed the other way.
Originally Posted by padresag View Post
It would be benificial to most to show what you used for a plug to plug that fitting in the frt tee. for the uninitiated they would have a problem with that ( knowing what it was, and inding a counterperson that knew)
ron
I plan on a complete listing when I'm done with this...thanks
you can buy a tube bender(not expensive), sandbag or you can find something which has the curve which you need and place the line on it and just slap the line with a flat piece of wood and form it around it. if you try bending it by hand you usually end up with a kink in it
ron
Sandbag.....thats why he mentioned the belly !!
Originally Posted by slepysal View Post
man I got to get mine done!! Thanks John this will be a great help
You welcome !!!
Originally Posted by ol Curt View Post
Did you have to bench bleed the master or is that just done for power brakes?
Chief might have got tied up with something or hasn't been on. anybody else know about bleeding the master?
Originally Posted by Captainfab View Post
All master cylinders should be bench bled regardless whether they are a manual or power.
Sorry man...I caught this nasty flu virus (that has gone thru my whole family and then some)...so I haven't been on here for a few days.
Thanks Captain....yes you should bench-bleed them. It amazing how much air is trapped in a new master.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-15-2009, 08:26 PM   #27
apachedaddy
apachedaddy's Avatar
I just got the drum/drum boster set off a wrecked truck. Going to put it on and get it working first. Once thats done would i order the same master but for a p/b impala to split the lines??
There is no kragens near me but there is a oreilly's are they the same because they come up on the same web page??
apachedaddy is offline   Reply With Quote
Old 03-15-2009, 08:36 PM   #28
truckdude239
truckdude239's Avatar
just a reminder to guys bending there own lines just remember if you have to flare please use double flares. i know its common sense please dont get offend.
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 03-15-2009, 10:21 PM   #29
joe231
joe231's Avatar
i just wanted to add..................the 67-up truck masters work also, they can be had in drum/drum or disc/drum for under $30 too.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-16-2009, 04:41 AM   #30
LILRED66
LILRED66's Avatar
Good stuff John...thanks for sharing.
LILRED66 is offline   Reply With Quote
Old 03-16-2009, 09:48 AM   #31
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yes....that is important, and thanks for mentioning that if I didn't.
Your Welcome !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-16-2009, 09:51 AM   #32
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yeap...that is corrrect. I went with an Impala, only because I had one sitting in the shop at the time for comparison.
Also, a '69 Vette will also be a dirrect bolt-up for a disc/disc !! Funny, how do I know about that ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-16-2009, 10:08 AM   #33
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
so chiefrocka if you are running disc /disc then you can use an impala or corvette master ,what year impala ?and will the master mount to a truck booster
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 03-23-2009, 10:24 PM   #34
jame
Can some one explain what had to be done to the original push rod. I gathered all the parts to do this but dont want to break down the system until I know for sure what is involved in making the master cylinder work correctly. Thanks
jame is offline   Reply With Quote
Old 03-23-2009, 11:20 PM   #35
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Sorry I haven't had a chance to finish this topic up, and make it a sticky....I haven't been on in a while. My pops is in the ICU and not doing so good.
If I remember correctly, all I had to do was loosen the jam-nut and extend slightly to achieve a slight endplay.
Additional pics will follow shorty, with a parts list, as with some editing and then it get STUCK !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-24-2009, 12:25 AM   #36
slepysal
slepysal's Avatar
I hope your pop is doing ok
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-24-2009, 12:50 AM   #37
Captainfab
60-66 Nut
X2.....I'll keep him in my prayers.
Old 03-31-2009, 01:50 AM   #38
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
you said a 69 vette could be used for disc/disc ,then what booster works good.
EAST
Old 04-12-2009, 12:51 PM   #39
1966gmc
Why does it taste purple?
1966gmc's Avatar
I just bought a new MC to do this and would love to know which fittings I will need to achieve this swap. I don't wanna start until I got all parts in hand
Hello, my name is John and I'm a truckaholic
1966gmc is offline   Reply With Quote
Old 05-10-2009, 08:56 PM   #40
Chuck78
ditto on the fittings list! I'd like to have it all ready to go so I can put it together in one evening.
No need to do any type of proportioning or metering valve to give the fronts more fluid in a drum/drum setup??????
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
Old 05-10-2009, 10:42 PM   #41
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
I bench bleed my MC's by bolting it up, filling the reservoir and running a line from the port to the reservoir and pumping it. I never understood using a vise, etc. Thoughts?
82 Chevy Blazer 4wd.RIP
1965 Chevy C10,350V8
Get it reliable,then puttin' it in the weeds..
"Old truck, all new headaches."
hAetWagon is offline   Reply With Quote
Old 05-11-2009, 08:07 AM   #42
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
No need for a prop valve when using a drum/drum....the master takes care of the pressure differences...
Sorry, I'll get the fitting list soon...
Works the same way....on a vise you can watch it closely thats all.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-11-2009, 12:40 PM   #43
BMSJaX
BMSJaX's Avatar
I always use the "in car" method. Has worked fine for me. Just install the plugs that come with the master and pump the pedal making sure not to move the piston more than 1 inch. I've also done it by hand holding the master in one hand and using a phillips screwdriver to pump the piston. Actually easier than it sounds
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 05-12-2009, 10:13 PM   #44
Chuck78
Thought I should add that on my 1962 GMC with the Dana 44 rear end, where the front 1/4" line tees off to the rear, my line to the rear is a 3/16" line. I wasn't sure if it was the same thread on the 3/16" line as the 1/4" inverted flare fittings (possible, didn't get to check), but I picked up a 3/16" adapter bushing in addition to the two other adapter bushings for the masters.
One was a 5/16" to 1/4" adapter, and the other one was 9/16"-18 to 1/4" I think. This fit my new remanufactured 1967 Chevy/GMC truck 1-1/8" bore drum/drum master cylinder. Got one piece of 60" line as I think I read someone else saying they needed about 51", and then I got a second piece 40" long to replace the line from the old master down to the first tee by the left front wheel. This piece will need to be longer on mine at least, since my 62 manual trans master has the lines out the bottom. The lines came double flared on both ends with the 1/4" inverted flare fittings already on.
Advanced Auto Parts and Car Quest both had drawers full of these adapters, so it makes it pretty simple. Take your master with you and bush it down to 1/4".
what I got:
*60" of 1/4" line w/two inverted flare 1/4" fittings (for new rear line)
*40" of 1/4" line w/two inverted flare 1/4" fittings (for front line, from new location on side of new master to tee at left front junction - might make do with a 30")
*1/4" inv. flare coupling or union
*1/4" plug
*5/16" tube x 1/4" tube adapter bushing for master rear line (check your master)
*9/16"-18 thread to 1/4" tube adapter bushing for master front line (check your master)
DORMAN Part # M66787 More Info {First Stop #18008616, 3912128, 3941939, 5458531, 5458905} w/Power Brakes; Bore = 1-1/8"; RWD; Bendix; Exc. 11000 Lb Rear Axle$50.79
On the bushing sizes, I believe the thread sizes in the master are 9/16"x18 and 1/2"x20, but I listed the way Advance Auto Parts has them on my receipt.
Also it should be noted that I am replacing a 1-1/8" bore master with a 1-1/8" bore master. I am adding a power booster (the old style that uses these deep bore masters same as a manual master's bore). I read in one article that said if you are switching over to power, you can get away with running one size larger master cylinder bore diameter. So I could have ran 1-1/4", but I hope to reuse this master minus the front residual valve for swapping to power discs, which would have used a 1-1/8" bore power brake master. Did I confuse you yet?
I'm also dealing with a 60-62, so I have to get rid of my stock clutch/brake combo master and install a separate clutch master in the stock location, and using a power booster and custom made booster bracket to give me the room to run the clutch master in the stock clutch master location. See my other recent thread on this topic.
I have not fit all this up yet, but based on Cheif's writeup, I think all of this is correct.
Chuck in Ohio
Old 08-15-2009, 02:33 PM   #45
slepysal
slepysal's Avatar
John you did have to drill new holes for the master right?
Old 08-15-2009, 02:44 PM   #46
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
No, not at all...it bolted right up.
Course, thats cause us 63 and up guys are special !
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-25-2009, 09:11 PM   #47
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
2 questions..
could Isee a pic of your tubing bender? not the belly the actual bender.
and, does this kind of system need a proportioning valve?
Old 08-26-2009, 09:15 AM   #48
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
It looks like this one....I also have the Matco double flaring kit.
Using a drum/drum master (two port Impala) you do not need a prop valve.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-02-2009, 07:16 AM   #49
ljackson
ljackson's Avatar
Hi Chief, Great write up. I am currently doing this on my '64. Got some questions. Did your old master have a 1" bore? What about the new one? My '64 is 1". The master at O'reilly's for a '70 Impala, drum/drum, no power, was 1 1/8. The master with a 1" bore was listed for discs with power. I believe I have read on other posts that using 1 1/8" master will make the brakes feel spongy. Do I have that right? Is the 1" bore the one to go with? I wonder if the parts store has it listed wrong? Thanks in advance for any help from anyone that can.
Eugene
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 10-02-2009, 08:50 AM   #50
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Not exactly sure, I'd have to research that.
I went with one from a '67 Impala. At the time, my buddys 67 Impala was in my shop, so I compared them.
The brakes on the black truck worked great...full pressure and never spongy.
My new truck will recieve the same treatment, although this one will get 6-lugs discs.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
