Old 03-19-2009, 12:20 PM   #1
rafterman191
Tranny guys help me. Thanks
Last night, my "new" 85 C10 long bed 305 ci, 350 tranny lost it. With no warning (to me at least) the transmission went. To get it to move, you can rev up the engine and get maybe 5 mph out of it on flat ground. When it went to shift last night, I heard and felt it slip, and then nothing. Checked the tranny fluid this morn and it's like gray soup. Anything I can do to isolate a problem or does it sound like tran failure? Keep in mind, there has been so prior slipping in the tranny. Could new tran fluid and filter bring her back? thanks for any help.
eta. removed the tranny pan. Fluid is more solid black than grey. Seems pretty gummy.
rafterman191 is offline   Reply With Quote
Old 03-19-2009, 01:56 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Tranny guys help me. Thanks
in all honesty if the fluid is that bad just change the whole thing i paid $525 installed for a rebuilt on mine last year they wont be more than that in any place that is reputable
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-19-2009, 02:39 PM   #3
rafterman191
There is a TH350 for sale about 20 miles from here for $50, says it worked when pulled.
Old 03-19-2009, 02:50 PM   #4
mrh33916
Project '67 454
mrh33916's Avatar
When you change out a transmission(which it sounds like you will be doing) make sure you clean out the lines going to the cooler and do not reuse the same torque converter as all these parts have debris in them,
mrh33916 is offline   Reply With Quote
Old 03-19-2009, 03:09 PM   #5
rafterman191
mrh33916 Clean out with what? Got a hold of the guy with the tran. Tomorrow probably go get it. I can spend $50 for another transmission not almost $600. I only gave about $400 for the whole truck, so it wouldn't make sense.
Old 03-19-2009, 03:24 PM   #6
mrh33916
Project '67 454
mrh33916's Avatar
When I do them I blow it out with compressed air, shoot a can of brake cleaner in one line and let it run out of the other into a catch can. Then blow it out again.
Old 03-19-2009, 03:28 PM   #7
rafterman191
Got ya, thanks. How bad would it be to use the old converter? I like the sound of $50 and a day under the truck. I could handle that. Can't find a converter for less than $170.
Old 03-19-2009, 04:19 PM   #8
Cherub
Cherub's Avatar
If it has debri in it it will severly shorten the life of your new/used transmission.
Cherub is offline   Reply With Quote
Old 03-19-2009, 04:57 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
Is your tranny a TH350 or a TH350C?
The TH350C has an electrical plug on the driver's side of the case (just above the oil pan) that is for the lockup convertor.
The trash in your tranny is ALSO in your tranny cooler, so IT needs to be flushed.
Old 03-20-2009, 03:11 PM   #10
rafterman191
So then why would I lose forward and reverse all at once?
Old 03-20-2009, 04:20 PM   #11
James McClure
One shot, one kill.
You lost forward and reverse because the pump can't pick up the gunk fluid in the pan and build pressure enough to apply the clutches in any gear. No matter what, replace the converter. You'll never get it clean enough to use. New trans don't come with one? jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-20-2009, 06:40 PM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Pull the govenor. It may be shot.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-21-2009, 02:18 AM   #13
rafterman191
not $50 ones
Old 03-21-2009, 02:03 PM   #14
rafterman191
It is a th350c. I want to swap with a th350. I suppose I need to address the wiring, and will definitely have to get a different tc. Anyone know anymore about this?
Old 03-21-2009, 09:30 PM   #15
piecesparts
Pull the plug and tape it up away from the tranny. Hang a TH350 in it's place (with a new Torque Converter) and drive the truck. You will see some differences in RPMs on the road from the TH350C---Not much though.
