lost lock nut socket
Hey,
my sierra's front tire had a bolt in it, which was holding the air hahaha, till it worn down enough for it to start leaking. Well the tires flat and i cant find my lock nut socket. Anyway to break this off at home? with out torch's / welder?
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
its all about the +6 inches
Re: lost lock nut socket
get a 12 point socket that is just a tick too tight, and hammer it on, use a breaker bar to turn it.
Two things that I have done is to borrow a wrench from my local yard and lacking the right wrench, I have welded a nut onto the special nut.
Cutting the nut of with a torch is very iffy as it is easy to mesh up the stud, Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
x2 on this. Most tool companies make a tool for this as well but socket usually works just as good. I usually use a 1/2 inch drive one so i can use my impact.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
Gone to greener pastures
![]() Join Date: May 2007
You know that one is going into the ol' databank, Andy.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
![]() Would it work for this kind of lock nut?
#7 | |
The other choice is that tire stores often have the special socket used to drive on and take the nut off. I'm not sure on that one H but you might get it with a stud puller. There is probably a socket that you can drive over it though either 12 or 8 like that 99th piece in your 99 piece tool set. Last edited by mr48chev; 03-19-2009 at 07:30 PM. |
mine was like this;
![]() I had to do this on my old GMC, truck came with the locks, but no key/adaptor. It worked so good, I just installed them back on the truck. I would imagine it would work on yours. Don't use high dollar snap on sockets, but you don't want to use craptastic ones made in china either. I honestly found that the craftsman ones seemed to be good at this task. |
![]() Join Date: Jan 2008
I've smacked them on the end with a hammer,then put a nice pair of vice grips on them and twisted them off!If you smack it good it will usually loosen them. My .02
huh?
![]() Join Date: May 2000
you can also take a junk socket about the right size, tack it on with a welder and take it off, done that before in a pinch.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
did you try a hammer and chissel.
![]() Join Date: Sep 2005
i just hammer on of my impact sockets on it and zip it off with the air gun
Those kind are a good candidate for the chisel method. Cut about a 1/4" strait cut into it. In one of those grooves would be a good spot. Then hammer it counter clockwise. A air hammer with a chisel bit is usually about a 5 min. job.
J'ville Junkman
![]() Join Date: Mar 2006
I would never try this, but I heard an urban legend that back in the day, you could take a can of freon and freeze the nut with it and it would become brittle, then you just hit it with a big hammer and it would break off. Look what happened to the Titanic!
Once again, I would never try this. Just something I heard. I'm not even sure why I volunteered this info. Must be bored. (Beating a socket on almost always works for me.)
72 3/4t Suburban 402BB (Daily driver for 8 years) ![]() 68 GTO (never ending proj) 91 Kawasaki ZX-7R 57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans) 73 Corvette (17 yr old daughter's: Another project - what's wrong with me?) ![]() 53 Willys M38 Last edited by BADSAM; 03-20-2009 at 09:19 PM. |
#15 |
Rods
![]() Join Date: Nov 2002
lol well they make a socket for this. its taperd on the inside. they sell them at northern tool and harbor fraight. u just put it on and it will bite down and cut into the nut till there is enough for it to take it off. also there is a tool called a nut splitter that will work here too
#16 |
Rods
looking at it you may be able to use a flat head and a hammer to tap it around till its loose enough for vise grips
#17 |
blood type; Retumbo
I bought a kit for these a few years ago. it cost like $15 and has like 5 different sized and types of sockets including a tool for locking hub caps. Harbor freight IIRC.
