#51 |
Re: My 57 Pro Street
very nice work Kim, hopefully I'll be starting my IFS this spring.
#52 |
Well I did some more work on the license plate.
I didn't like the first piece I made for it so I made another ( the first one wasn't square). Did a layout of where it would go drilled some holes and then conected them. |
#53 |
I still have to finalize the final depth of it but you can get a little idea of what it will look like.
Kim |
#54 |
The UPS guy droped this off at the house today.
Found it at Pirate Jack for $89.00 which was way cheaper than anywhere else. Seems to be a real nice piece and their customer service was very good. Kim |
#55 |
very nice truck you have there, i like the box idea, very original. as for the pedal assembly, that is what i should have done, oh well live and learn.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#56 |
Did some more work on the plate mounting.
The pics are self explanatory. I just have to do some finish welding and grinding and it'll be good to go. Kim |
#57 |
The UPS guy dropped off some more goodies.
These are the upper and lower control arms I'm going to use. They are made by SPC. The ball joints are tall polished Howe units. The lower A-arms will drop the suspension 1" over what the stock ones would set at. Kim |
#58 |
Certified Car Nut
Hey Kim,
It looks like you are really picking up the pace on your build. Nice job on the bed and the goodies look great. |
#59 |
#60 |
Certified Car Nut
Me too. Its just that time will not agree with me, I just keeps running out.
#61 |
PROJECT 7DEUCE
Wow very nice idk how i missed this thread?
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#62 |
I seen a bed close to your's on a truck on e-bay. Did you see it? It was red and chopped and really nice. I think it was in Dallas.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
#63 | |
It's a work in progress that keeps changing as I go along in the build. I pretty much have it the way I want it now and just have to do a little finish welding and then get it primed. Kim |
#64 |
"Where were you in '62?"
![]() Join Date: Jul 2004
ME LIKES THE HINEY!
I would love to set my Ole' "Project: Full Metal Yellow Jacket"
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#65 |
Nice fab work. I went out and threw rocks at mine after looking at your work.
#66 |
1Bad62
Thanks for the compliment. Kim |
#67 |
dennis57
Thanks. I've been watching your build and like what you've done. I have to fix the steps on mine also and appreciate seeing how you did yours. Kim |
#68 |
No problem.........
Once you go Pro........ You never go slow............ ![]() http://cid-9169aad55cfc6d79.skydrive...ACKET%e2%80%b3
#69 |
1Bad62
Very nice truck. Did you use trailer fenders for the tubs? Kim |
#70 |
Under Construction
Nice Work Kim!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#71 |
Thanks 'til you're better paid
Way cool. Very nice fab work. I cant believe I missed this thread too! Can't wait to see a full view of the truck when you get the bed done!
-Luke 1950 Chevy AD 3100 pickup 2000 GMC Sierra 1970 Jeepster Commando |
#72 | |
Wish we hadn't did that. Would of been better using these ![]() Was wanting to buy this Fiberglass Bed for my 62 from USBody, but had alot of people say know. Do not do buisness with them. Anyhoot....
#73 |
Thought I would post some updates on what I have been doing to my truck.
Pic #1 is a hydroboost unit out of an 05 chevy truck. The next 4 pics show a bracket I made to mount the unit on the frame. The bracket will mount just under the back of the cab witch will put the hydroboost and the master cylinder behind the cab for easy access. I will connect it to the brake pedal with some DOM tube. Kim |
#74 |
These next 2 pics show the finished bracket and unit bolted to it.
I had to modify the mounting flange that was on the unit to work with my bracket. Kim |
#75 |
I also had to modify the push rod on the unit so it would attach to the pedal.
I cut the end off the push rod and rounded it off. I got a 3/8x24 grade 8 bolt and some 3/8 ID DOM tube. I cut the head off the bolt and rounded that end also. Kim |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
