Old 03-20-2009, 09:22 PM   #1
Schralper
Schralper's Avatar
Need alignment, real world specs
ok so i got the 68 outta cold storage, free from the snow around it.
after taking it for a quick spin last eve,
i think i need to get the camber adjusted.
noticed wear on outside edge of tires
it tracks str8, had it running 90+ for a few miles.
seems good other than a lil bouncy
i'm running 245/60R15 bfg radial t/a front tires, 2.5" drop spindles w/ about 1 coil cut from stock spring. air bag inside coil, 5psi, a lil soft so probably goin back to 8 psi.
what's everybody running for spirited road driving?
this in not just a str8line truck
http://www.cardomain.com/ride/2658591
Schralper is offline   Reply With Quote
Old 03-21-2009, 03:41 AM   #2
smashedfoot
Re: Need alignment, real world specs
try -.5 deg. camber and get as much positive caster that you can to help high speed stability. and an 1/8 inch toe in. make sure you set the ride height where you are going to drive it or your specs will change and cause excessive tire wear and poor handling.
smashedfoot is offline   Reply With Quote
Old 03-21-2009, 08:23 AM   #3
cparman
sharp as a marble
I agree with Smashedfoot. My 69 has drop spindles on the front, and when I aligned it I was looking for 0 degrees camber, and went there first. After getting that ( or close ) I fiddled with trying to get as much positive caster as I could. What you will find is that you will run out of bolt on on both rear bolts. In a perfect world the right side should be a bit higher than the left IE: right side caster 1.5 degrees + on the left side 1 degree + this will help the truck track straight. all roads have a crown to them, and the spread in the caster will compensate for this.
cparman is offline   Reply With Quote
Old 03-21-2009, 11:30 AM   #4
Schralper
Schralper's Avatar
right on i'll try those specs and see how she goes.
thanx
