Old 03-22-2009, 11:47 PM   #1
shooterpcb
6 lug to 5 lug rear?
what is the best and most inexpensive way to convert to 5 lugs in the rear?
1968 C-10 2wd, short bed fleetside, 355 Chevy, TH350, 12 bolt pegleg, '81 Camaro cowl induction on hood(I don't like it, previous owner did it), 10" wide 15"wheels.
shooterpcb is offline   Reply With Quote
Old 03-22-2009, 11:49 PM   #2
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: 6 lug to 5 lug rear?
the best way is to buy new axles, but the cheapest way may be to locate a complete rear?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 03-23-2009, 12:03 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
being that you have a 68 with the narrow rear axle, I would advise locating a 71/72 rear end with the same style springs yours has, and installing the complete assembly.
Old 03-23-2009, 12:18 AM   #4
Pont406
I am slowlly doing the same with my 69 c10. I am real close to ordering a 5 lugs replacement axles. Why is 71 rear and up better? Thanks
Pont406 is offline   Reply With Quote
Old 03-23-2009, 03:35 AM   #5
ERASER5
ERASER5's Avatar
Because when you convert the front drums to disc, the track width gets wider. Drop spindles? Even wider. In 1970-1/2 the rear axles were widened to match the upcoming 71 disc brakes.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-23-2009, 04:30 PM   #6
GMC3
i pulled my 69 axles out of the rear and took them to a machine shop and had them re drilled for 5 lug and the hub shaved down. very easy and pretty inexpensive
GMC3 is offline   Reply With Quote
Old 03-23-2009, 08:20 PM   #7
djracer
djracer's Avatar
Neil I have all the front 5 lug stuff and I can help you find a rearend.
Kevin
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
