Old 03-25-2009, 11:22 AM   #151
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Here is a "Not Your Typical" 4wd Blazer build
Bad azz...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-25-2009, 07:41 PM   #152
sandking
.....I am working on it.....
sandking's Avatar
Thanks guys!! Just lacking funds right now. Hopefully soon, I will make some progress again.
View my build thread HERE
sandking is offline   Reply With Quote
Old 04-13-2009, 10:30 PM   #153
onlyifihadachevy
Seeing this i want to try and build a 4link front and rear then a cage. Will most likey have to have to pay for it.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 04-16-2009, 12:30 AM   #154
sandking
sandking's Avatar
It's really not as hard as it looks. It would cost so much more to have a shop do it.
Old 04-16-2009, 02:44 AM   #155
onlyifihadachevy
i could get a shop to use but i dont know how long it will take and how to set it up would it would be easier to do it with the leafs and the blocks still in it. i belive the offer my uncle gave me is still valid he said he would give me his king coilovers because theyre too big. i might call him today i guess see if i could use his shop this weekend and if he would give me some ideas to build it.
My 72 thread
Old 04-16-2009, 08:27 AM   #156
sandking
sandking's Avatar
You can use leafs, but get Deavers if you are going that route.
Free Kings? Take 'em.
Old 04-16-2009, 05:21 PM   #157
onlyifihadachevy
i mean to set it up instead of moving the axle to find the center.
My 72 thread
Old 06-06-2009, 11:03 PM   #158
sandking
sandking's Avatar
Well, it's been awhile since I have done anything to the Blazer. I have been doing lots of research on my Gen III engine and getting all the parts for the cam swap. Also had a hard time finding a wiring harness for the engine because it is from an ;07 Tahoe, it is almost too new for aftermarket stuff, but I learned almost all of the extrior is the same as an LS2. I was able to get my stand alone harness done. In the next few weeks, I will get the engine moched up in the Blazer with the motor mounts, then I will get the engine back together.
As far as fab work goes, I got the front suspension and steering almost complete. Just need to fine tune, clean up then shoot some painty on everything. The geometry of the cross over steering was a bit difficult to fit and eveything work together as the suspension cycles 14". Because of the extra up travel, I had to move things around to clear each other.
Tomorrow, I am working on a list of parts for my brake lines. Again, because of the amount of travel, the brake lines will have to go from the master to the rear of my trailing arms, then back up to the calipers.
Enjoy
Old 06-06-2009, 11:06 PM   #159
sandking
sandking's Avatar
I have lots more.......
Old 06-06-2009, 11:10 PM   #160
sandking
sandking's Avatar
More...
Old 06-06-2009, 11:10 PM   #161
VA72C10
VA72C10
VA72C10's Avatar
That thing is a beast!!!
Old 06-06-2009, 11:12 PM   #162
sandking
sandking's Avatar
These last one show the fuel system stuff and the engine wiring harness.
Old 06-06-2009, 11:20 PM   #163
sandking
sandking's Avatar
I needs to be able to withstand my heavy-ass foot when I hit the dirt
Old 06-06-2009, 11:39 PM   #164
little nick D
man the works super clean an the tube notching/fitting is way *****in!!!! keep it up
little nick D is offline   Reply With Quote
Old 06-06-2009, 11:49 PM   #165
Billhilly
Billhilly's Avatar
Really nice work sandking. The hours required to think about, then fab up, and then actually get this sort of stuff to work is alarming huh?! You must be happy to have this much done. Going to be a great truck.
Bill.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 06-06-2009, 11:50 PM   #166
sandking
sandking's Avatar
Thanks man. It very time consuming!!! The fabbers on t.v. make it look so easy, yeah right
Old 06-06-2009, 11:51 PM   #167
sandking
sandking's Avatar
Bill.
Yeah, happy to be this far, but I have so much more to go. I can hardly wait to get it going.
Old 06-06-2009, 11:55 PM   #168
sandking
sandking's Avatar
Oh yeah, before someone asks about the welding on the steering arm, I did not have much of an option. The aftermarket arms are too long otherwise I would have had to push the steering box forward 6" more then the 3" I already did. I think it will be ok. The majority of the arm is still inside the new plating, I just cut off the ball joint part. So, there is not much stress on the new welded area.
Old 06-07-2009, 12:00 AM   #169
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
Any info on the fuel system? I am about to have to run all my fuel line from the fuel cell to my 5.3 and Im not really sure where to start. lol
p8ntballer1911 is offline   Reply With Quote
Old 06-07-2009, 12:16 AM   #170
sandking
sandking's Avatar
Sure, what do you want to know? I have -6 from the fuel cell to the filter, to the pump, to the regulator, than to the fuel rail. From the regulator back to the cell with a -6 for the return. I got a Summit high flow pump, 40 micron filter and a high pressure regulator.
Old 06-07-2009, 02:21 AM   #171
abadsvt
abadsvt's Avatar
Love the build! I think you are doing a bad a$$ job on the truck. Really looking forward to seeing it completed!!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 06-07-2009, 12:24 PM   #172
sandking
sandking's Avatar
Thanks for all the good words!!!
Old 06-08-2009, 12:16 AM   #173
sandking
sandking's Avatar
I just had to get a visual with the tires on.......
Old 06-08-2009, 01:21 AM   #174
VA72C10
VA72C10
VA72C10's Avatar
Sweet!
Old 06-08-2009, 02:02 AM   #175
Billhilly
Billhilly's Avatar
Nice!! Looks great.
1972 K2500 Long Box
400/350
