Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-26-2009, 02:34 PM   #1
1BAD70CHV406
Weight Removal
How much weight and what can be removed out of these trucks, iv been looking at how to make it lighter but cant seem to find anything besides replacing body panals with fiberglass ones...
1BAD70CHV406 is offline   Reply With Quote
Old 03-26-2009, 04:18 PM   #2
Wild83C10
Wild83C10's Avatar
Re: Weight Removal
I'm around 3500 lbs and hope to be at about 3400 or less next year.
How much does your truck weigh and what have you done so far?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-26-2009, 05:43 PM   #3
low&slow
Re: Weight Removal
im doing the same with my truck...you can start by taking out your inner finder wells in the front and by taking out all gas tanks and putting a fuel cell in.
low&slow is offline   Reply With Quote
Old 03-26-2009, 09:07 PM   #4
Wild83C10
Wild83C10's Avatar
Re: Weight Removal
I wouldn't take out the inner fenders, throws way too much crap around the engine compartment. What happens when you accidentally run over the dead skunk on the side of the road and that crap is all over your hood and everything else?
turbo=
Old 03-26-2009, 09:33 PM   #5
AlienYouth
AlienYouth's Avatar
Re: Weight Removal
i've been thinkin about this too, i'm at 4200, if i could get close to ur 3500, i'd be runnin 12's all day NA, that would make me happy
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 03-27-2009, 12:43 AM   #6
Super73
Super73's Avatar
Re: Weight Removal
Here are a few things I have done. The last time at the track it weighed 3,850 with me in it with 1/2 tank gas (2,050 on the nose 1,800 in the rear):
Remove heater and lines (guessing 15lbs)
Removed front bumper (25lbs?)
Bought alum wheels over steel wheels
Switched to manual steering (30-35lbs?)
Removed factory tank and installed fuel cell in the bed (honestly think it was a wash but better location)
Thing I had done to help adjust weigh bias before last outing:
Moved the batterey to the back
Again the fuel cell vs gas tank behind the seat
Things I am doing or that have changed since the last outing:
Fabricated replacement front x-member (25lbs)
Removing the tow hitch I put on the truck when I first bought it. (Guessing 30lbs)
Remove the spare gate I filled with 100lbs of metal.
Ditch the bech seat for something lighter (Summit seats saved me 50lbs)
Fiberglass front end (guessing 180lb savings)
Removing brake booster and going to run manual brakes (5-10lbs)
Other places that can help shave weight:
Switch to a Mustang 2 style front end
Back half it and run a 4 link or a ladder bar
Build a full new frame
Run a different tranny (Glide?)
Buy glass pannels
Lexan windows
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-27-2009, 12:40 PM   #7
Garagedude
Garagedude's Avatar
Re: Weight Removal
I wonder how much weight i lost, I cut the whole bed out and all the cross pieces, I have an aluminum fuel cell, and wheel wells, the battery is moved to the back, I am running an aluminum kirkney racing seat, no front fender wells. Manual brakes, Manual steering, Ultra light gauges and dash panel, I have lexan to go in the back window and the side windows. Disk brakes probably added weight right? Aluminum wheels, no heater or blower or any of that.
Garagedude is offline   Reply With Quote
Old 03-27-2009, 12:58 PM   #8
Alex1
Alex1's Avatar
Re: Weight Removal
What have you done to get the weight so low? My 80 step with all iron BBC is like 4400lbs
Alex1 is offline   Reply With Quote
Old 03-27-2009, 02:44 PM   #9
team39763
Re: Weight Removal
Got any pics of how you did your bed? I was planning to cut the floor out of my bed, but I'd imagine I need the weight over the rear axle right?
team39763 is offline   Reply With Quote
Old 03-27-2009, 10:39 PM   #10
Garagedude
Garagedude's Avatar
Re: Weight Removal
I will post some tommorow I can't find any saved on the computer
Old 03-28-2009, 07:13 AM   #11
Wild83C10
Wild83C10's Avatar
Re: Weight Removal
I would think cutting the bed out would hurt you more then help. Removing weight is good, but not when you take it away from the rear.
I'm tring to think about how I can add weight to the rear.
turbo=
Old 03-28-2009, 07:24 AM   #12
Wild83C10
Wild83C10's Avatar
Re: Weight Removal
I removed everything from the engine compartment. I have an aluminum radiator, SBC w/alum. heads and intake. It has power steering, thats it. I have lightweight racing bucket seats. I removed the dual tanks and put in an aluminum fuel cell in the rear. removed the overload spring, but added caltrac bars. Aluminum wheels.
I will be installing a C4 dropmember and probably a manual R&P. All the C4 components are aluminum (control arms, calipers, ect) so I should be able to shave another 50-100 lbs there.
turbo=
Old 03-28-2009, 07:51 AM   #13
Garagedude
Garagedude's Avatar
Re: Weight Removal
I don't think cutting the bed out and putting aluminum tubs and fuel cell in was a bad idea at all, yes I know that cutting more weight in the back doesn't help all the time, but you can oways add more weight, and position it in certain spots.
