Old 03-27-2009, 05:47 AM   #26
Rob73-87
Rob73-87's Avatar
Re: Whats This Electrical Contraption?
Originally Posted by lurch115 View Post
if the truck was converted from a diesel to a gas that relay and such would have stayed with the diesel since the diesels don't use a distributor, and they also have different valve covers.... that and the glow plug controller is larger than that relay...
Believe me - GM won`t mount a relay to a valve cover !!!!??? As I said, I have the same relay too, and my truck came with a TH700 - so it can`t be the kickdown-switch....
Any idea ?
Rob73-87 is offline   Reply With Quote
Old 03-28-2009, 09:11 AM   #27
sierra4x4
sierra4x4's Avatar
I think you may be right f.monroe becouse my 84 3/4 ton 350/Th400 has one and I have a buddy with a twin to my truck (both optioned identical both bought new by a construction outfit) the only differance is that his was a 305/700r4 and his truck does not have it.
sierra4x4 is offline   Reply With Quote
Old 03-28-2009, 01:40 PM   #28
Dezdon
I looked in my Haynes 67-87 chev/gmc repair manual and couldnt find anything on it. It does look OEM to me. I have seen these over the years.
My suspicions:
Cruise control system
Power steering or a/c activation sensor(when a/c kicks on or power steering, it senses the load and changes something in the RPM or something.
A factory option not being used.
Something to do with emissions?
I'll ask a few old time techs I know next time I see them and post back if I have anything.
But it runs the same with out it?
Dezdon is offline   Reply With Quote
Old 03-28-2009, 02:14 PM   #29
JohnC
JohnC's Avatar
Could it possibly be something that only Canadian trucks have? The two that say they have it are both in Canada.
JohnC is offline   Reply With Quote
Old 03-28-2009, 08:41 PM   #30
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
It's a GM installation. I've seen it posted. I'll try to dig it up or find what it does.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-29-2009, 12:05 AM   #31
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I will have to eat my shoe if it is proven to be OEM because I don’t believe it is a GM installation for a second. I have had my head of under hundreds if not more of these trucks and have never seen a relay on the valve cover. I just cannot wrap my head around the idea GM would ever mount a relay on the engine of all places. Yes, the reply is a GM relay but that means nothing. The same part number of relay could be used in any circuit that would require a relay…heck you could use the GM relay on a Dodge if you wanted. The harness could look OEM as well if the aftermarket supplier purchased connectors from the Packard (old GM electrical supplier) back then. That happens a lot still today….many aftermarket suppliers use Delphi connectors for aftermarket components for ease of installation into GM products. The turn signal lights on the ARB front bull bar I just bought for my ’05 HD is a good example of aftermarket companies using GM supplier components.
That said, I am 99.9% sure that is an aftermarket dealeo of some sort unless it is something specific to Canadian trucks.
DirtyLarry is offline   Reply With Quote
Old 03-29-2009, 12:55 AM   #32
enaberif
Why would ANYONE install something onto the valve cover.. that is what baffles me.
enaberif is offline   Reply With Quote
Old 03-29-2009, 01:40 AM   #33
73chevyman
73chevyman's Avatar
after looking at your first pic looks like you got a water leak from your bell housing noticed radiator fluid on your intake
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 03-29-2009, 01:46 PM   #34
Dezdon
Now that I look at it, your right, that cant be a OEM install. I would think if GM had something on thier valve cover, it would have a bracket spot welded to the valve cover and raised up off the surface. then the relay would just kinda clip in place.
This thing is just nut and bolted through the valve cover, not a factory engineer style.
What about one of those after market A/C kits, or a snow plow adaptor electric component.
Old 03-29-2009, 01:48 PM   #35
Dezdon
Hey, what about one of those old "knox" device kits from the 70-80's from California emission laws?
Old 03-29-2009, 10:31 PM   #36
Blue85
Oilfield Trash
Blue85's Avatar
If you look close at the pic there is a bracket spot welded to the cover,sits about an 1/8" off, and the stud is welded to the bracket, after thinkin about it I can almost guarantee this had some thing to do with the emissions system that used to be on the truck. Heres what ive figured out on it so far, gets main power from the bat wire goin to the coil, it uses voltage from the tach to activate the relay, mabye it was used to activate a canister purge solenoid when the rpm was in a certain range. I sont really have the tools to check how much voltage the relay opens at, but thats what ive figured so far.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 03-30-2009, 07:14 PM   #37
lurch115
lurch115's Avatar
i just can't wrap my brain around this either....that relay looks like a heater relay to me (for the blower motor) and i just have a hard time believing that GM would mount a relay to a valve cover like that...the constant heating up and cooling down would kill it. especially since it is cased in metal....if i am wrong i am wrong....just going off of what i know from what i have seen.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-30-2009, 07:20 PM   #38
lurch115
lurch115's Avatar
okay, now i have to eat my words....if you look at chapter 6 (emissions control systems) page 3 (6-3) of the Haynes repair manual...in the 2nd picture down on the left hand side of the page you will see the relay...but as to what it is or does...still not sure...i'll thumb through the whole book if i have to to find out though....
Old 03-30-2009, 08:03 PM   #39
rafterman191
Originally Posted by Longhorn321 View Post
You're not on here asking about a F@%d are you?
hehe, I just chuckled at that one.
rafterman191 is offline   Reply With Quote
Old 03-30-2009, 08:58 PM   #40
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I just looked in my Haynes book. It is the 67-87 Chevy and GMC pickups book. On page 213 and 214 it describes the Throttle Return Control (TRC) system. It holds the throttle open slightly when the engine is coasting. It consists of the wiring harness, the
"Engine Speed Switch" (the thing we are trying to figure out) and the TRC solenoid.
It even shows a picture of the switch mounted on the valve cover on page 214.
I'm sure this is the mystery box...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 03-30-2009, 09:07 PM   #41
Blue85
Oilfield Trash
Blue85's Avatar
I think we have a winner lol!
87 Chev 3+3 4x4
Old 03-30-2009, 09:08 PM   #42
Blue85
Oilfield Trash
Blue85's Avatar
BTW here is a pic of the bracket it sits on.
87 Chev 3+3 4x4
Old 03-30-2009, 09:14 PM   #43
ElGracho
ElGracho's Avatar
Here's a blurry digital picture from page 214, right column. I don't have a scanner...
Joe
Old 03-30-2009, 09:17 PM   #44
Blue85
Oilfield Trash
Blue85's Avatar
You must have an older manual than me, mine is in sections, like 5-12, what section of your manual is it in?
87 Chev 3+3 4x4
Old 03-30-2009, 11:03 PM   #45
Longhorn321
Size Matters
Longhorn321's Avatar
That would explain the wire going to the dizzy.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 03-31-2009, 03:36 PM   #46
Rob73-87
Rob73-87's Avatar
Red face Re: Whats This Electrical Contraption?
wow, - now check this out! - He is proved correct. GM actually mounted those relays on valvecovers.... sorry I really couldn`t imagine..
Old 03-31-2009, 03:46 PM   #47
JohnC
JohnC's Avatar
El Gracho you are the MAN
Old 03-31-2009, 04:20 PM   #48
DirtyLarry
DirtyLarry's Avatar
I will start eating my shoe as well. I would have never guess GM would mount any relay on the valve cover. Someone pass the Tabasco souce please.....
Old 03-31-2009, 08:04 PM   #49
cjracing15
cjracing15's Avatar
Well I will be diped.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 03-31-2009, 09:36 PM   #50
Square84
I don't think these pills work
Square84's Avatar
my buddy has a 85 1 ton with a 350/th400 and his has it but he has an edelbrock carb and if you unplug his the truck won't start?
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
