Old 03-28-2009, 12:57 AM   #1
Daniel 61 Apache
Daniel 61 Apache's Avatar
Project 61........................It is what it is.
I finally got my ass in gear and started working on my truck. What started as replacing a shock has evolved into a engine tranny swap, front crossmember swap, disc conversion, and air ride suspension.............all at once.
Gotta start somewhere right? Well, here's the pics.
Here's the before pictures. I love the way this truck looks. The hood is *****in and the stance is tough with the gangster wide whites.
Check out those lake pipes!!
Stock 307 from a Chevelle mated to a TH350 which will be swapped for a 305/700r4.
Started by yanking off the bed and all suspension components.
Ended up moving the work to a friends shop in Port Clinton, Ohio. I'm still new to this and he's a pro. So it helps having some experience to bounce ideas off of.
At his shop we blew off the front clip, crossmember, and pulled the engine/tranny. First thing on was the new crossmember and power booster.
For anyone swapping a crossmember into a 60-62 X-Frame heres a couple of pics of the holes that need drilled out. There are two along the side of the frame rail and only one will need to be drilled out a bit.
The ones on the bottom of the frame rail.
Wire wheeled and flat blacked the front frame rails and crossmember.
Still waiting on the drop spindles and rotors so it's off to the back to get the bag mounts in.
Air Tank will look good right here.
Daniel 61 Apache is offline   Reply With Quote
Old 03-28-2009, 12:58 AM   #2
Daniel 61 Apache
Re: Project 61.....It is what it is.
Look at all the rust.....Time for the wire wheel again!
That looks 10x's better.
Thats all for now. Gotta go out of town for a few days and hopefully the rest of my parts will get here in the meantime. Time is ticking.......
Old 03-28-2009, 01:14 AM   #3
Captainfab
60-66 Nut
That's coming along nicely.
Why do you want to swap the 307 for a 305? The 307 is a better engine IMO.
Old 03-28-2009, 07:47 AM   #4
62 short step
62 short step's Avatar
Looks good!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-28-2009, 07:55 AM   #5
orange66fleet
Lowered in Cleveland
Looks like it is going to be one sweet ride. Nice to see another member in northern Ohio.
orange66fleet is offline   Reply With Quote
Old 03-28-2009, 08:26 AM   #6
bosephus
bosephus's Avatar
Definately digging your project,nice work!Keep us posted and the pics coming.What kind of dodge is that hiding under that cover?
bosephus is offline   Reply With Quote
Old 03-28-2009, 09:28 AM   #7
mano
mano's Avatar
What year motor mount brackets did u use. They look like mid 70's 80's brackets. Super cool build.
mano is offline   Reply With Quote
Old 03-28-2009, 09:55 AM   #8
jason65
Registerd User
jason65's Avatar
Looks like it was a little hell raiser. You gonna keep that look?
jason65 is offline   Reply With Quote
Old 03-28-2009, 11:28 AM   #9
Daniel 61 Apache
The 307 needed a full rebuild, new cams, pistons, carb, headers, intake, lifters, etc..........The 305 was bought turnkey with all accessories for $600. There's more parts for the 305 and it was just the cheaper route honestly.
That would be a Challenger with a 440 under the hood. It's the shop owner, Brian Barnett's. Frame off resto and the thing is sick. Rattles your soul when he fires it up.
Motor mounts are from the 86 C20 that I pulled the crossmember out of. The top that would normally bolt on the frame rail is going to be cut off and welded to my frame rail. We'll set the engine in first and tack it once the engine is level, pull the engine and weld it all up.
Hell yeah! Maybe 15 years from now my kids and I will pull it apart and restore the body, you know a family project. For the time being I like the look of it. I just want to be able to drive it, safely.
When I got the truck the rear shocks were halfass welded on, the torsion bars were cranked all the way out till it hit the bumpstops up front, and the brakes.......Only one drum worked, the front right one. Anytime I stopped it would pull violently to the right! Now I'll feel comfortable putting my wife and kids in it to go to the store.......oh and I will finally have power steering!! WooHoo!!!!!!
Old 03-28-2009, 01:48 PM   #10
Corts60
Just here to tinker
Corts60's Avatar
That is a sick truck you have there. Can't wait for more pics!
Old 03-28-2009, 02:33 PM   #11
joe231
joe231's Avatar
Nice!!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-28-2009, 04:11 PM   #12
protrash64
Resistance is Futile
protrash64's Avatar
I dig 'skeletor the proctology patient' on the antenna!!!! Cool truck; watch out for that panhard tagging your diff cover when aired out. Looks good.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-28-2009, 04:17 PM   #13
kizer
Its Deja Vu time again
kizer's Avatar
Wow that does look really nice. Glad to see another person grinding on their frame
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-28-2009, 07:37 PM   #14
Daniel 61 Apache
There's actually a lot of room between the two. Not really anyway that they will hit each other.
What you meant to say was, "Glad to see another person having to go through this **** too!"
Project 61 build thread
Some people spend an entire lifetime wondering if they've made a difference....The Marines don't have that problem.
Sic vis pacem, para bellum. -- "If you want peace, prepare for war."
Old 03-28-2009, 08:17 PM   #15
19GMC63
19GMC63's Avatar
VERY nice... I like your style.
19GMC63 is offline   Reply With Quote
Old 03-28-2009, 08:40 PM   #16
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Great progress on a good lookin' truck.
Alan's Classic is offline   Reply With Quote
Old 03-28-2009, 09:08 PM   #17
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Looks like you are penning the blueprints for the next phase of my 61' project. Thanks for the detailed pics...and keep em coming!!!
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 03-28-2009, 09:26 PM   #18
Daniel 61 Apache
No problem. I could never find any pics or builds that bagged and converted to discs on here. I figured I'd throw a build post just for us X-Frame guys.
Old 03-28-2009, 09:28 PM   #19
terd ferguson
terd ferguson's Avatar
I love the color of your truck. More pics.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 03-29-2009, 08:37 AM   #20
bosephus
bosephus's Avatar
Your killing me(and my laptop which now has coffeeall over it)
Old 03-29-2009, 09:29 AM   #21
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Nice look'n truck man....leaving the body like that right ??
Sweet !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-29-2009, 10:57 AM   #22
64c20crewcab
64c20crewcab's Avatar
nice!!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 03-29-2009, 01:37 PM   #23
Daniel 61 Apache
Yeah the body will be staying the same. There's one dent on the entire truck though, front left fender. I've got one to replace it but if I can't match the color I'll leave it alone. That one non matching off colored fender would drive me crazy....
Old 03-29-2009, 10:24 PM   #24
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Subscribed! Great looking truck, dude.
I'm glad you told how you went from fixing one shock to motor/tranny swap and bags. I was thinking that must've been one real tough nut to remove or something.
-- Will
killthewabbit is offline   Reply With Quote
Old 04-03-2009, 08:59 PM   #25
Daniel 61 Apache
I needed one thing to break.....that was all it took to convince my wife I had to upgrade a "few" things!
