Old 03-28-2009, 11:54 AM   #1
terd ferguson
terd ferguson's Avatar
Replacing a Cab VIN Question...
Let's say one was to replace their cab with one in much better condition. Since the VIN plate is on the cab, and assuming the replacement cab didn't have a title, what would you do as far as the title is concerned? Is it legal to swap the VIN plate from the bad titled cab to the non titled replacement cab? If not, what would one do in this situation?
Thanks in advance for any info and thanks for this great forum.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 03-28-2009, 12:07 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Replacing a Cab VIN Question...
There are a couple different ways to do this.
1) Call your DMV. Chances are they will issue you a new VIN tag after the swap. They will check the VINs on the old cab and new cab to make sure everything is clear.
2) Swap your old VIN to the new cab using the rosette syle rivets. Is it legal? No. If the police figure out what you did will you get into trouble? Yes. How will they figure it out? I don't know. If you choose this one you maybe shouldn't post exactly what you did on the internet.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-28-2009, 12:09 PM   #3
terd ferguson
10-4. Thanks.
Old 03-28-2009, 12:53 PM   #4
Daniel 61 Apache
Daniel 61 Apache's Avatar
Swap it.
Daniel 61 Apache is offline   Reply With Quote
Old 03-28-2009, 04:39 PM   #5
502tripower
502tripower's Avatar
Its done all the time. It only makes sense to use the better parts. If you have a better cab use it.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 03-29-2009, 01:03 AM   #6
Captainfab
60-66 Nut
Contacting your state vehicle inspector is probably the correct and legal way to do it, so they can issue a new VIN for it. However be prepared to have all the requested documentation for your purchase for every single part you are building your truck with. Even then there is no guarantee that you will get a new VIN. The inspector may see something he or she doesn't like and refuse to issue a new VIN for your truck......could be they're just having a bad day. At least that's been the way it works around here.
Old 03-29-2009, 10:06 AM   #7
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Here in Arizona, if you do it legally they will issue you a salvaged title making your truck worthless IMO. If you do it illegally and are caught this can look like it was stolen to law enforcement agencies. Tough choice??
66Gilbert is offline   Reply With Quote
Old 03-29-2009, 10:10 AM   #8
orange66fleet
Lowered in Cleveland
When I bought my truck I had no Id Tags in my truck, both were gone, so I bought a vin tag that they use in the hot rods at my work and hammered in the vin and took it back to the inspection and had no problems.
orange66fleet is offline   Reply With Quote
Old 03-29-2009, 02:02 PM   #9
protrash64
Resistance is Futile
protrash64's Avatar
I would not tell anybody anything.....its just the way you bought it..get it?? What someone doesnt know isnt going to hurt them in this case....I would do it without hesitation.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-29-2009, 02:14 PM   #10
LILRED66
LILRED66's Avatar
Install the new VIN tag on the cab in the correct location and take the title and truck to your local DMV for inspection. If questioned, the VIN tag was removed during the restoration process, to preserve it and reinstalled upon completion.
LILRED66 is offline   Reply With Quote
Old 03-29-2009, 02:45 PM   #11
BarryB
BarryB's Avatar
Ditto, plus were talking about an over 40 year old truck.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 03-29-2009, 11:41 PM   #12
502tripower
I guess the first thing to ask is do you presently have a tittle to any of the above vehicles/Cabs registered in your name already? If not go do it. Then swap the cabs. If you already have it registered in your name then all you have to do is swap out the cabs and vin tags. Remember to use the correct rivets.
98' FXD
2002 2500HD
Old 03-30-2009, 01:15 AM   #13
terd ferguson
My rig is my daily driver and is titled, registered, tagged, and insured in my name. Everything but the cab is in awesome shape. The cab itself has some problems that may be easier (cheaper) solved by swapping out for a better cab than trying to fix it all. For instance, the windshield has a crack, there is a hole above the windshield, and there are a couple of holes in the floor. If I could find a knee knocker cab with no holes and a good windshield for $500 to $800, it would almost be a no brainer to swap.
I've got other priorities, but I'm quickly running out of things to do besides fix my cab or swap. I'm down to bodywork/paint and interior. Besides the cab, the worst part of the truck is the lower doors and the're fixed easily and cheaply enough. Aside from the cab, bodywork/paint is just taking it down to metal and then spraying. So now I just have to decide is it worth it to fix my cab or would it be better to swap. The decision would be a whole lot easier if one were to come up locally for a good price.
