Old 03-29-2009, 11:13 AM   #1
mjensen
mjensen's Avatar
It actually runs!!!!
Well, I was able to make some good progress this weekend. It starts and runs like a champ! It is missing a bit under load, so I hope to go out and check the ignition system today.
The way it should be
Name:  the way it should be.jpg
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-29-2009, 11:22 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: It actually runs!!!!
Nothing like getting something to work on your own. Feels good don't it!
Nice trucks you have there, That GMC looks right at home in the garage.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-29-2009, 11:46 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Great going! Another old truck brought back to life... I bet the neighbors ain't too pleased, though.
I had one call the city on me cause I had my old 69 parked in the driveway unlicensed. Had to move it out to my country property.
68gmsee is offline   Reply With Quote
Old 03-29-2009, 11:48 AM   #4
mjensen
mjensen's Avatar
My neighbors are actually pretty cool. One of them said "let's go around the block". Of course what do you do? We went around the block...a few times
Mike
Old 03-29-2009, 11:53 AM   #5
Boog
laying low
Boog's Avatar
Good neighbors you have there.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-29-2009, 12:20 PM   #6
mjensen
mjensen's Avatar
I do have a question about the miss. It still has points, and I'm only familiar with the points systems in VWs. Do they slowly go out, or is it an all or nothing thing?
Mike
Old 03-29-2009, 12:29 PM   #7
Boog
laying low
Boog's Avatar
Yes the points do wear down some. The point gap will close up with wear. I don't know what your plans are for the truck but probably a full tuneup is in order if you intend to run it much. I would pull and inspect all the plugs, check the vacumn advance, check the points dwell, timing, fuel filter and such. If you don't have a dwell meter you can get it real close with a feeler gauge. Around 28-32 on the dwell angle.
Boog
primer is finer
Old 03-29-2009, 03:04 PM   #8
dan42
dan42's Avatar
Consider trading out the dizzy for an HEI unit - huge upgrade at a small price. I got a new one on Ebay for around $75.00.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-29-2009, 04:21 PM   #9
mjensen
mjensen's Avatar
I actually have one from my brother-in-law's 400 SB. I just bought a new cap, rotor, and coil for it. So I may just swap it out.
Mike
Old 03-29-2009, 04:27 PM   #10
spinning wheels
spinning wheels's Avatar
Before you install the HEI, read some of the post on this site. You will need to get 12 volts to the dist. The stock set up only has 12 volts when you start it, then drops to 7 1/2 volts. With this low voltage, you will fry your module in the HEI.
It is not rocket science, and someone with limited knowledge of car electronics can do it, (like me).
Oh yeah, did your give you the spark plug wires?
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-29-2009, 04:29 PM   #11
mjensen
mjensen's Avatar
No, I was going to replace the plugs and wires as well when I do this. I've been searching for tips on this swap. Is there an FAQ on this?
Mike
Old 03-29-2009, 04:33 PM   #12
spinning wheels
Not sure about FAQ, but there should be a few posted threads. Just do the google search, at the top of the page.
I learned about this problem the hard way, by frying an MSD module and had to have the truck, flat bedded home. That was about a $120 lesson
Old 03-29-2009, 04:35 PM   #13
mjensen
mjensen's Avatar
Well, I'll search around and see what I can find before I make the swap. I imagine from what I've read so far, the points definitely need to be adjusted on this truck. That might be all I do today
Mike
Old 03-29-2009, 04:40 PM   #14
spinning wheels
Unlike the type 1 VW, they will be a little harder to adjust as the dist. is in the back. But its the same process.
Good luck.
Old 03-29-2009, 04:42 PM   #15
mjensen
mjensen's Avatar
Good luck.
Sweet! I'm very familiar with the VWs so we'll see how that knowledge transfers
Mike
Old 03-29-2009, 06:17 PM   #16
mjensen
mjensen's Avatar
Well, changed the oil and bought the parts for the HEI
I think I'll tackle this next weekend after researching the h3ll out of it
Mike
Old 03-29-2009, 06:26 PM   #17
Jtrux
I'm a poor spectator
Jtrux's Avatar
It's easy to do. Run a pretty thick (10 or 12 guage) wire with a spade connector under the dash to the fuse box (the box has accomadations for the spade connector. Then hook the other end to your dizzy. Viola!!!!!
OR...
If you must be different you can run it to a relay mounted on the fender that will completely isolate it from everything else which isn't really necessary but you can do it. It's up to you, the first way I said is WAAAAAAAAAYYYYY easier and quicker.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 03-29-2009, 07:34 PM   #18
americanmusc1e
americanmusc1e's Avatar
OR...
I did mine with a spade connector just like that, runs fine
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
