Old 03-16-2003, 01:01 AM   #1
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
Angry yay! my rockers don't fit!
LOL
so i ripped the driver's side apart today (first day of the year warm enough to work without freezing my arse off) to put the new panels on it and YAY! there seems to be a gap between where the rocker and the panel it should weld against... something like a 2"? gap almost right where the sill plate bolts onto. I was thinking this may be related to me taking the door off that side but i looked on the other side with the door still on and it looks like i'll have the same problem on that side.
the other problem seems to be one rocker is slightly smaller than the other... it seems to taper down...? there's definitely a difference in shape between the two rockers... weird. maybe someone just stepped on the little one and i just gotta bend it back?
oh, and i tried to take the rear bumper off today with a nice big impact wrench my dad got from work and much to my surprise, even with the help of a lot of WD40, the bolts holding the bumper on will not even turn a little. it's insane. i was worried this wrench was gonna rip my arms off (or at least cause some kind of pain or blood when it rips the bolt from the frame) but it seems to be really wimpy in the face of the mighty GMC 910... LOL, i mean really, really wimpy. it ain't got shi*t on those little bolts.
well, out comes the gas-axe i guess.
1968 GMC 910 Long Step 250/3onTree
1969 Chevy C10 longfleet, 350/350
68_GMC_910 is offline   Reply With Quote
Old 03-16-2003, 01:26 AM   #2
orange72
orange72's Avatar
or out comes the 1/2in wrench with a 4ft cheater bar on the end of it.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 03-16-2003, 03:19 AM   #3
JHickson6
I Love This Stuff!
JHickson6's Avatar
Hey another Winnipegger, good to see, but I can't offer you much help for your rocker panel problem. Can i ask where you got them from?
Thanks Good Luck
Jared
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 03-16-2003, 03:59 AM   #4
bigvinnie
bigvinnie's Avatar
you shouldn't be having the fitment problems you describe... there seems to be a lot variance in the quality of replacement panels... I would see about returning these and finding better ones... the place I got mine from had cheap ones and expensive ones... I tried the cheap ones and then returned them for the expensive ones, big difference in fit...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 03-16-2003, 04:21 AM   #5
Southpa
Southpa's Avatar
I think there are 2 kinds of rocker available, one is a partial which is welded to an intact sill plate area (outer edge) and the other is the full rocker that includes the whole top surface. Take it back and get the full one. Bumper? I managed to snap half the bolts getting mine off. A solid length of pipe on the ratchet handle usually gets things moving.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 03-16-2003, 04:43 AM   #6
COBALT
COBALT's Avatar
Screw the 1/2" drive breaker. Go with the big-dog 3/4" drive. Heat the bolt up with a propane torch, and whack it a few times with your hammer, then put pressure on it. Repeat until the bastard moves...soak it with some lube first the night before and let it sit for a while (I wouldn't bother with WD-40. There's some WAY better alternatives, but I'm at a loss for names right now. Anyone else???).
For my trailing arm bolts I actually used my floor jack to push the handle up on one, and for the other I used a bottle jack to push the handle down. It was the only way I was going to get enough pressure (no leverage) to get them loose.
Good luck.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-16-2003, 10:34 AM   #7
greasemonkey
greasemonkey's Avatar
Some people swear by PB Blaster (?) I've never tried it but it's supposed to break stuff loose.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 03-16-2003, 10:47 AM   #8
TODDS 72
Not the nightly winner
TODDS 72's Avatar
PB Blaster is the best imo...and i've tried them all..but with bumper or frame bolts nothing beats the blue wrench.....lol
72C10SWB BLUE 350/350
86K10LWB BLUE 5.7 700r4 7.5' fisher plow
93S10XCAB4X4 BLUE 4.3 4L60e
69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green
86k15 swb5.0L 4spd brown
TODDS 72 is offline   Reply With Quote
Old 03-16-2003, 10:52 AM   #9
lunatic
lunatic's Avatar
I had the same problem taking my back bumper off,I cut them off with a grinding wheel....
lunatic is offline   Reply With Quote
Old 03-16-2003, 10:59 AM   #10
racedvl
racedvl's Avatar
I had the same problem with my replacement rockers, and being I was 3 hours away from home to do them, and didn't wanna drive it around without rockers at all, I put them on, and the ends with the gaps look like hell. But I figure, I can go back and fix it later down the road.
racedvl is offline   Reply With Quote
Old 03-16-2003, 12:55 PM   #11
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
heh... i should have mentioned that the rockers came with the truck... they look pretty cheap. I totally can't return them...
well, I guess I could still use the big rocker on one side and get a new one for the driver's side.
Old 03-16-2003, 04:42 PM   #12
Southpa
Southpa's Avatar
Another option is to weld a patch panel into the sill area and then weld the small rocker onto that. Or copy the full size rocker by fabricating and welding a patch onto the little rocker. Any clean scrap metal will do and the sill plate will cover any imperfections anyway.
Original 350/TH350
