03-29-2009, 08:36 PM | #1 |
help me please!!!!!!!!(lowering my truck)
i have a 69 swb 2wd stepside chevy c-10 v-8 with a 72 5 lug conversion and i want to lower it 3/4 or something like that what parts do i need to do it help me please!!!!!!!!!!!!11
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
03-29-2009, 08:42 PM | #2 |
Eat My Rust
Re: help me please!!!!!!!!(lowering my truck)
Lowering springs front and rear are the easiest. Would cost about 220 or so shipped to your front door. Drop shocks are recommended IMO, and they can be found at Doetch for like 55/shock, and they ride AWESOME.
03-29-2009, 08:44 PM | #3 |
If you have leaf rear you can use blocks or lowered leaf sets. If you have coil rear you can use srpings, blocks combo. In front you can use a combo of springs and drop spindles, depending on how low you want to go.
03-29-2009, 08:46 PM | #4 |
a shock relocation kit for the rear and adjustable panhard bar too
03-29-2009, 09:09 PM | #5 |
i would recomend the drop spindals in the front without them it is hard to align the camber right
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
03-29-2009, 09:16 PM | #6 |
Eat My Rust
Nothing a good tech can't do.
03-29-2009, 09:23 PM | #7 |
pics would be nice and i have rear coils
03-29-2009, 09:43 PM | #8 |
Tot Roddin'
Just contact the guy's at ECE (Early Classic Enterprises), and they will hook you up and answer any and all questions you might have.
Check out this page for shots of different drops on the same truck... LINK
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-29-2009, 10:12 PM | #9 |
yes its possible, im a full time alignment tech but before i put drop spindlas in mine i hada heck of a time getting mine right i say if you go 3'' or more in the front without bags it is best to use drop spindals
03-30-2009, 03:30 PM | #10 |
well i want to do it cheep but not to cheap ya know what i mean?
03-30-2009, 04:04 PM | #11 |
Moderator
2.5" dropped spindles in the front, 4" drop springs out back. It will ride like a Caddy.
03-30-2009, 10:16 PM | #12 |
what would that run me? does anyone have pics of tehir lowered trucks?
03-31-2009, 03:39 AM | #13 |
Here is shot of rear, 1 1/2 block from stockcarparts .com, new ubolts from local spring shop, and 2 inch drop springs. Total cost about 150. Front has one and half coils cut out. Truck sits level. I drive a 1 ton truck daily so no different ride to me.
03-31-2009, 01:53 PM | #14 |
what is the best way to do it because i am going to charlotte and i will be looking for these parts
03-31-2009, 10:52 PM | #15 |
I dropped my 70 quite a few years ago when I was in college and all I did was take a coil and a quarter off the front springs and then made 3" drop blocks for the rear trailing arms and this is what the truck sits like. (when it was done back in 95')
04-22-2009, 10:12 PM | #16 |
i really like that stance
04-22-2009, 10:31 PM | #17 |
resident oilfield trash
Good luck on Cheap after all was said and done my wallet was about 850$ lighter
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
04-22-2009, 11:27 PM | #18 |
Back when I lowered my truck I think I bought a pair of longer u-bolts and that was about it. I scrounged for the steel to make the rear lowering blocks. May cost a couple of barley pops if you need to get the blocks drilled or welded up.
04-23-2009, 02:35 AM | #19 |
Blocks springs trac bar c notches spindles front springs I didnt realize it at the time because I bought it piece by piece but that added up to 850
04-28-2009, 09:07 PM | #20 |
wow i think i will go with 2.5 front spindles and springs and rear lowering springs what do you all think?
04-28-2009, 09:17 PM | #21 |
Under Construction
I say go for it...
we installed ECE's 2.5 dropped front spindles, with 4" dropped rear springs, shock relocators, and adj. trac bar......
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
04-29-2009, 05:12 PM | #22 |
If you use the 2/4 drop springs from lmc with the drop shocks can you just bolt it in and go?
04-29-2009, 07:52 PM | #23 |
If you stay with steel 15" wheels then stay with a 2 1/2" spindle. 3" drop spindles have a tendency to rub the rim on the lower control arm.
04-29-2009, 08:09 PM | #24 |
WTB this ad
If you can't afford to do it the way you want (and properly), save your money til you can. You'll be happier with it in the long run.
If you haven't seen this yet it could prove to be helpful... http://www.67-72chevytrucks.com/vboa...light=saturday |
