Old 03-16-2003, 07:12 PM   #1
Xzavior240
Xzavior240's Avatar
tach problems
ok I was messing in the 71 today since its about 75 degrees out. and I was trying to hook up the factory tach in the dash. if I tap the guage the needle bounces so Im pretty sure it works. the problem is the motor doesnt move it. theres two wires on the back of the dash panel. one is running to the tach plug on the HEI cap. the other is running to the fuse block. is this right and any ideas as to why its not working if it is? any help would be appreciated
thanks,
Dan
71 chevy C10 LWB 2WD runs and everything
79 chevy 1/2 ton Big Ten silverado gonna part it out since it left me walking.
69 f100 real good shape with lots of go go juice
89 plymouth reliant (daily driver)
86 thunderbird sitting in the weeds almost covered (anyone need parts?)
WWW.xschunkofthenet.freeservers.com
nothing there I promise
" tell me I'm a sinner I got news for you. I spoke to god this morning and he dont like you" OZZY
Xzavior240 is offline   Reply With Quote
Old 03-16-2003, 07:20 PM   #2
Andy4639
Old member
Andy4639's Avatar
Cool TACH
Make sure the tach is hooked to the tach side of the dist. cap. It's marked and make sure you have the metal tab that goes in the cap in place, I have seen these missing before. Yes the wires should be as you said.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-16-2003, 07:22 PM   #3
Xzavior240
Xzavior240's Avatar
yeah its hooked on right on the dist. the only thing I can think of is the wires may be bad since its hooked up right. is there a right and wrong plug to hook them to on the tach?
Old 03-16-2003, 07:28 PM   #4
Alex Hayley
Make sure the tach is well grounded...To test my tach while it was out of the truck, I wired the body of the tach to a good ground and that made the difference.
Alex Hayley is offline   Reply With Quote
Old 03-16-2003, 07:31 PM   #5
Xzavior240
Xzavior240's Avatar
I didnt think about that it should be grounded though its bolted in tight and the dash is real solid actually.
Old 03-16-2003, 07:33 PM   #6
Alex Hayley
Did you try switching the wires on the back of the tach?
Old 03-16-2003, 07:34 PM   #7
Alex Hayley
And...I am sure you are correct...if the tach is installed in the dash you should be good for ground.
Old 03-16-2003, 07:34 PM   #8
Xzavior240
Xzavior240's Avatar
not yet Im getting ready to do that when Im done jumping back and forth between posts. which is going to have to be soon the suns going down
Old 03-16-2003, 08:23 PM   #9
Xzavior240
Xzavior240's Avatar
ok after a long lengthy descision ( mainly unplugging things and plugging them back in so many times my hand hurts from hitting stuff up under the dash) and with a lot of choice words. Ive come to the desicion of I dont think it works. perhaps I'll just find another somewhere. whats the cheapest place for replacement clusters? and can I buy just one of the parts of do I have to buy them all?
Old 03-16-2003, 08:32 PM   #10
Alex Hayley
I am sure you buy just the tach if that is all that you need. I think I saw a tach for sale on the parts board for $50.
