Old 03-16-2003, 07:17 PM   #1
jkvette719
No Spark?
I have a H.E.I. and lost spark. So I replaced the Ign. module and coil and still no spark. The Dist. is an Accell and isnt that old so I wouldnt think it would be the pick-up. It has power to the coil to when you turn the key on. Any ideas? thanks Justin
jkvette719 is offline   Reply With Quote
Old 03-17-2003, 12:17 AM   #2
DRASTiK
Converted Ford guy
seems like there isn't much more that it could be. It's always possible that you got a bad module or coil. They are supposedly all tested before being sent to the stores, but I've got bad modules before right out of the box. You could have them tested, and if they're fine, then I'd have to say the pickup coil unless you have a wiring problem somewhere.
Dave
DRASTiK is offline   Reply With Quote
Old 03-17-2003, 12:40 AM   #3
CRRoy71
I had the same problem with mine not too long ago.
Did a total tune up, plugs, wires, cap, everything including the module. Tried to start it and no spark. The module was a Borg Warner I think. I took it back and had it tested and sure enough it was bad. Swapped it for an AC Delco and it started right up.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 03-17-2003, 12:58 AM   #4
jkvette719
ill try the module.....it ran fine last week! thanks guys
Old 03-19-2003, 10:15 PM   #5
gmcbob
gmcbob's Avatar
How often are you guys replacing your module in your HEI Dist? It seems like mine goes out every six months or so. And I've even tried different brands, and even gone to GM for a new one, but they keep going out.
Bob
Bob
1978 GMC Sierra Classic K15 Shortbed, 350/350/NP203, 31's on Rally's, Restored to Stock Condition. Two-tone Russett Metallic / Buckskin.
1987 GMC Sierra Classic V1500, Longbed, 350 TBI, NP205, 33’s on Chrome Spoke with 4” Suspension Lift. Black.
2014 GMC 2500HD 4x4 Duramax Crewcab
gmcbob is offline   Reply With Quote
Old 03-19-2003, 10:41 PM   #6
rage'nrat638
rage'nrat638's Avatar
Question why not msd
why dont you guys run MSD its great they make one for your stock ing. or you can buy there box to they may even make a coil
for stock ing, check out summits web site or jegs. just a though.
MARK....if you buy the 6al them you've got a rev.limiter....
rage'nrat638 is offline   Reply With Quote
Old 03-20-2003, 12:39 AM   #7
PHOENIX
I also had problems with stock modules and replacements. They would go out at random and I hated it. I got a new distr. (Proform $150) and it did ok for awhile, then that module went out. I bought the msd module and the msd module off another member. No problems so far and it does seem like it idles smoother, but really no change in performance from what I can tell. My big thing is that I hope it doesnt just up and stop like the other modules.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 03-20-2003, 12:42 AM   #8
PHOENIX
For those curious, heres some comparison pictures:
Old 03-20-2003, 08:26 AM   #9
jkvette719
Does that come with the install kit or something?
I have vac. adv. will that matter? Thanks jUstin
Old 03-20-2003, 09:16 AM   #10
CRRoy71
I haven't had my truck a year, and I have already replace two. That is due to getting a bad one from the parts store the first time though.
If it keeps up, I will consider going with something like the MSD.
Chris
Old 03-20-2003, 09:49 AM   #11
swervin ervin
You get what you pay for
swervin ervin's Avatar
Just a word on Eddie's module. It is made for 4 pin module distributor's. If you still have an ESC distributor, it's 5 pin, and the MSD module won't work. They don't make a module for a 5 pin ESC distributor.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-20-2003, 10:38 AM   #12
BigRed
I have heard of so many module problems, but I guess I'm in the minority. I've had my truck for over a year and have had no problem with the module (crossing my fingers!).
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-20-2003, 02:13 PM   #13
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Same here. I still have the same HEI that came with the ZZ4.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-20-2003, 03:04 PM   #14
PHOENIX
Mikes right. The ESC is a 5 pin. When I changed to the proform it was a 4 pin. I did notice that once I got away from the esc system, I had way less problems with the module. Sotck type module would last me about 1 to 1-1/2 years then just stop.
Old 03-20-2003, 07:06 PM   #15
jkvette719
mine is a 4 pin so im good there
Old 03-20-2003, 07:10 PM   #16
Bill W
Did you use the dielectric grease on the bottom of the module before you installed them? I've never had a module go out.
Bill W is offline   Reply With Quote
Old 03-20-2003, 07:11 PM   #17
rage'nrat638
Thumbs up summit racing
you can get it at summit racing in about 3 days or next day if you want... mark
