Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-31-2009, 05:45 PM   #1
rrspeed
99 S10 blazer odometer display
I have a 1999 s10 blazer that recently developed a problem with the odometer and shift indicator display. As I'm driving, the display will sometimes blink on and off and sometimes go out completely. Has anyone had this problem before and if so, how did you diagnose the cause and what was the fix.
Thanks!
rrspeed is offline   Reply With Quote
Old 03-31-2009, 07:20 PM   #2
BarryB
BarryB's Avatar
Re: 99 S10 blazer odometer display
Sounds to me you have either a bad ground, or the wire connecting into the back of the cluster, has some slop in it. Only way to really diagnose it is to pull it loose and jiggle the wire to see if you can repeat the problem. Because sometimes just from normal driving, the wires can break inside the insulation and loose contact.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 03-31-2009, 10:10 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
bad cluster or as it's correctly called and IPC. welcome to the wonderful world of late model GMs.
68C15 is offline   Reply With Quote
Old 04-01-2009, 04:13 PM   #4
rrspeed
Thanks, I sure miss my old 72 c-10!
I started another post with the new maladies the odometer is presenting me. The odometer won't advance and the trip meter numbers change every time I start the truck. Just shoot me. lol
Old 04-01-2009, 09:23 PM   #5
rockabillyrat
68c15 is right gm has cluster problems ive seen so many cavaliers at work that come in with these issues. you will need a new cluster
rockabillyrat is offline   Reply With Quote
Old 04-13-2009, 08:37 AM   #6
rrspeed
Can you tell me how to get the old cluster out? COuld this problem be related to a transmission code I got when we scanned the truck?
Old 04-13-2009, 10:03 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
My X used to own my Blazer and she had related these type of things and I have never seen it. Could it be possible you have a bad battery, battery ground corrosion, or your alternator is failing??? Sounds like the others know whats up, but thought Id throw it out there anyway.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-13-2009, 11:48 PM   #8
rockabillyrat
if the battery or alt. was bad you would have more problems then just erratic gauges. plus the battery light will come on way before you see any running issues.
and transmission codes will not be part of the ipc. im sure it uses the ecm to monitor the transmission sensors and will set the check engine light.
the cluster is held in by the plasic panel around it. take it off and you will see the screws that hold the gauges to the dash.it can be a pain in the ... to get it owt but im sure you wont have to big of a problem
Old 04-13-2009, 11:49 PM   #9
rockabillyrat
oh and only the dealer can reset the milage on the odometer if you swap out the ipc we send ours in at work.
