04-01-2009, 12:00 PM | #1 |
Picking up a bed, what size trailer?
I'm headed up north to get a shortstep for my project and I need to get a trailer that can haul an assembled bed. I think the beds are 6'6" x 6' approx. and I've got some ideas from what I've seen, but just wondering what trailer size you guys suggest.
Thanks, Anthony |
04-01-2009, 12:58 PM | #2 |
Re: Picking up a bed, what size trailer?
i'd get a 10foot if available
04-01-2009, 01:13 PM | #3 |
My 16" dove tail works great for it.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
04-01-2009, 02:00 PM | #4 |
Active Member
Unless you're going to buy a trailer, I'd see if I can borrow one from a friend if the happen to have one. I saw a guy haul a bed on a small trailer like the ones used to haul a riding lawn mower -maybe 8' to 10'. He had some 2X4's across the trailer rails, then the bed upside down and strapped with tie downs.
If you rent one a 16' trailer should be enough. Over here I can rent one from around $35 to $50 a day. |
04-01-2009, 02:36 PM | #5 |
I was planning on renting a small trailer from u-haul and I think there is a 6x12 for $30 a day. What I've seen in the past is the 2x4 across the rails with the bed upside down. Will a bed even fit inside a 6x12 trailer? I figured the deciding factor would be the width, not the length.
04-01-2009, 03:43 PM | #6 |
You can use almost any trailer, but sometimes you just have to get creative
If you can get the fenders off, it should fit easily inside, but it could take hours to unbolt (GRIND) the bolts out. Upside down would probably be the best bet if you can't get a flat trailer. I looked at U-haul when I got my bed, but none of their trailers were wide enough. So I borrowed this one from a friend and pre cut a couple 2x4's at lowes.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-01-2009 at 03:46 PM. |
04-01-2009, 03:55 PM | #7 |
it will easily fit a 6X12 if the fenders are off// bring grinder and extension cord to grind off bolts to remove fenders
04-01-2009, 03:55 PM | #8 |
I am guessing you have a topper on your pickup, or you are driving an SUV, but if you are driving a pickup with an uncovered bed, you could do the 2x4 deal on your pickup and ditch the trailer idea.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-01-2009, 04:20 PM | #9 |
Parts and more parts
If you have a short bed truck, turn the bed upside down and put a couple short posts in the stake pockets and haul it home on the back of the driveable truck.
04-01-2009, 05:07 PM | #10 |
Thanks guys for the ideas, I'll more than likely go with a small trailer and use 2x4's with straps.
The tow rig is my brother's '05 Dodge Dually 4dr and I doubt he's too keen on the idea of strapping it to the bed of his truck. Are the fenders bolted on or riveted on? You guys talking about grinding the bolts off makes me wonder, how many bolts are there per side? |
04-01-2009, 05:59 PM | #11 |
The fenders are bolted on, no idea how many bolts.
If you are going to pull the fenders then haul the stepside bed in the bed of the Dodge.
04-01-2009, 06:14 PM | #12 |
laying low
Just did a quick check of my stepbed. It measures 58 1/2" across the top by 80" long. This is the box only. Add another 16" to the width measurement if you leave the fenders on it. So the assembled bed with fenders overall measurements are about 74" wide by 80" long. Now use that to see what size trailer you will need.
04-01-2009, 06:15 PM | #13 |
Saving 1 truck at a time!
10 bolts and 4 brackets at least per side. You will also have to cut the 6 or so bolts connecting the step to the fender and another 4 connecting the step to the box...it will take forever...trust me!
I would use two 2x4's (8" wider than the Dodge box) and invert the box on the Dodge...easy to load and easy on both beds. Use fabric between the Dodge and the 2x4. Nail blocks (2x4x4) sections on the outboard side and inboard side of the 2x4's to keep the box from sliding sideways. Here is one on my Toyota...WORKS GREAT at 75 no sway or anything! You can see the forward 2x4 w/blocks next to the shirt sleeve of the guy on the right and the rear 2x4 w/blocks near the rear of the Toyota box. Easy to load by tipping the box on its end and carefully laying it over on the first 2x4 toward the back of the truck. Then pick up the other end and walk/slide it forward on one 2x4 and place the second 2x4 under the back,
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 04-01-2009 at 06:32 PM. |
04-01-2009, 06:17 PM | #14 |
Do what stllookn recommends. The great thing is that the box is narrow enough that you can use the tie downs that are inside the bed, so you will not have straps going outside of the bed on his nice paint.
04-01-2009, 08:55 PM | #15 |
Active Member
I don't believe he mentioned that it's a stepside...
Either way, there's a lot of bolts to remove from the sides and inner fenders. I'd just take the 2X4's like you're planning and 3 or 4 good tie down straps and that should do it. As you can see from the pics submitted, it's not a big deal and lots of ways to do it. |
04-01-2009, 08:59 PM | #16 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-02-2009, 12:21 AM | #17 |
Resident of Here
6x8 will do, just lay 2x4's across it and lay the bed on them.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
04-02-2009, 07:34 AM | #18 |
blood type; Retumbo
you don't want it in the first place. step sides are a waste of time. instead get a long fleet bed.
BTW, where is the stepper bed at and how much $ is it? I could come and get it with my Honda. LOL |
04-02-2009, 11:51 AM | #19 |
Haha, that would be a long drive to Texas from SD
