Old 04-02-2009, 01:22 PM   #51
Damien
Damien's Avatar
Re: Horrible gas mileage
[QUOTE=Rain City;3232573]Will the PCV Valve even help my gas mileage? /QUOTE]
No, the PCV will not affect your mileage, but it will make your enging last longer.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 04-02-2009, 01:31 PM   #52
73chevyman
73chevyman's Avatar
think that truck use to have the 3 port mechanical feul pump thats what that hose could be for. do you have a vacuum gauge. if so hook it up to your manifold vacuum if at idle your not in the range of 15 to 20 means your carb is out of wack. do you have any idea how to adjust your carb. if you don't i'll find something for ya to help you out. also check your timing, your truck should be set at 12 degrees advanced due to the fact you have a automatic trans. check the timing with the vacuum advanced off.
http://www.youtube.com/watch?v=6vKlA...eature=channel
watch this video it might help you
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-02-2009, 01:42 PM   #53
73chevyman
73chevyman's Avatar
look on your radiator support it will tell you your gap rating for your plugs along with timing setting and so forth but you might not be so stock by looking at your motor. don't get frustrated just take your time and you'll get it right. sounds to me they didn't tune your carb right. read this too this should help out
http://www.centuryperformance.com/tu...e-spg-148.html
73 C10 Fleetside
Old 04-03-2009, 04:56 PM   #54
Damien
Damien's Avatar
I just had a thought as long as we are talk spark plugs. What about the heat range?
Old 04-06-2009, 02:29 PM   #55
UltraBlue71
UltraBlue71's Avatar
I wonder if the metering rods for that old Holley are the correct ones, where did the PO live? Ask him what kind of mileage it got. You didnt gain or loose alot of altitiude when you took it home did you? Everyone has opinions and this is mine, Get a Quadrajet, for your 350 have someone who knows what they are doing (not me, I never could figure a Q-jet out or make one work right) rebuild it and install it. They have little primaries and huge secondaries and are one of the finest carbs ever built as far a fuel efficiecy goes.
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 04-06-2009, 02:46 PM   #56
Adams74Chevy
Adams74Chevy's Avatar
Any recommendations on Q-jet gurus? I have one I'd like to get rebuilt right.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 04-06-2009, 07:31 PM   #57
billnorman
Hey. Umm I would not route those plug wires so close to the headers, it will cause them to fail from the heat. That fuel filter unscrews, I fear them for that exact reason. If it unscrews while you are driving, good insurance will have been a smart investment. HOT ROD magazine had a good article about getting good gas mileage from Holley's. Something about putting a restrictor in the idle circuit. Your truck runs on the idle circuit unless you really stick your foot into it.
billnorman is offline   Reply With Quote
