Old 04-02-2009, 04:38 PM   #1
jeremiah king
jeremiah king's Avatar
tilt column help
have a standard tilt column. shift lever wont lock into place.
is there a spring or sometime behind it to hold pressure against it when you shift. any pix would sure help.. thanks
jeremiah king is offline   Reply With Quote
Old 04-02-2009, 07:53 PM   #2
JimKshortstep4x4
Re: tilt column help
If you pull back on the lever does it spring forward? If not pull the lever and check the spring that is installed into the housing at the opening where the shift lever comes out.
If the spring is ok then the detent is worn or the shift lever is worn where it contacts the detent.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-02-2009, 08:42 PM   #3
70Custom10Nut
70Custom10Nut's Avatar
I agree with above. I just replaced the detent spring in mine because I munched it when I replaced the shift lever. Does it lock in to place when you manually push the lever forward? if so, it's the spring. if not it's the other. The spring is easy to replace, but tough to find. Just make sure you use a small screwdriver to keep from destroying it (like I did) when you put the lever back in. Good luck. Cnut
70Custom10Nut is offline   Reply With Quote
Old 04-02-2009, 09:37 PM   #4
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
If you need a spring I'll be glad to give you one.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 04-03-2009, 04:37 AM   #5
OhioDan
OhioDan's Avatar
Is this what you're looking for? Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 04-03-2009, 06:08 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
when you say "standard" I assume you mean "conventional automatic". most of the time it is the spring that goes bad. look in the above pic near the bottom center, above the bowl is the spring. up a little ways you see the plate which is retained by the two screws. although rare this can get worn out from people not pulling the lever far enough.
68C15 is offline   Reply With Quote
