Old 04-06-2009, 02:34 AM   #1
nekkidhillbilly
overdrive for a k20
im new to the forum
but anyhow i dont care about it holding crazy amounts of power on anything so my question is what can i do about putting a od tranny to this be it a 700r4 2004r 4l80e or something of the wall even
cheapest is best
nekkidhillbilly is offline   Reply With Quote
Old 04-06-2009, 03:44 AM   #2
Prong
Re: overdrive for a k20
Cheapest route would be a 700R4 and NP208 T Case out of an 80's 3/4 ton. You may also need the driveshafts if they don't make a conversion U-joint.
Prong is offline   Reply With Quote
Old 04-06-2009, 04:13 AM   #3
nekkidhillbilly
wasnt the np208 in the half tons also
another question what about the later trucks transfer case the 241 or what ever its called can i use it and the 700r4 out of say a 92 or will it mess with the shifter location or something
Old 04-06-2009, 04:18 AM   #4
nekkidhillbilly
truck is a 84 btw
Old 04-06-2009, 04:03 PM   #5
kevinr1970
I think if a 3/4 ton truck/Sub had an OD tranny they also had a 208 TC. I think they are considered "light duty".
I am 99% sure the newer body trucks (88+) and Sub's (92+) have a driver side drop transfer case so I would look out for that.
I would do some number crunching before making the swap. If you are not in need a of a tranny anyways it will take quite some time for the tranny swap to pay for itself even if you get all the parts for quite a deal.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-07-2009, 05:17 AM   #6
nekkidhillbilly
im not dropping a fully built unit in this thing just something from a junk yard i can swap in
my 200-4r i got for my car cost me 50 bucks. its a gn one too and had a 700r4 offered to me for 200 bucks so i cant see it being a big cost. i have no clue about drivers side drop what does tha mean. im not wanting a off road machine or anything just something i can do 65 in and get better than 6 mpg. i have an 04 to tow with and all.
i have considered getting the tbi 350 4l80 and transfercase from a later truck and mounting in the 84 but the issue again is the transfer case drive shaft mods arent a issue i can have them modded cheaply.
Old 04-07-2009, 06:53 AM   #7
nekkidhillbilly
ok i read up figured out that the new trucks have the drive shaft on the drivers side
so can i use something from a dodge ford or what
sorry for all the questions im new to these trucks
Old 04-07-2009, 07:29 AM   #8
Gleekr
for sure the cheapest/easiest is to find a complete trans/transfer combo from a 82-87 truck or 82-91 blazer/burban with the later trucks watch for the electronic speedo that some had
Gleekr is offline   Reply With Quote
Old 04-07-2009, 01:35 PM   #9
Russell
Professional Grade
Russell's Avatar
You can bolt a 32 spline NP208, or pass side drop to any transmission from a newer truck. All of them use the same 6 bolt round transfercase output.
I've got an 04 NV3500 transmission in my 1980 with a NP241 transfercase from a 91 Suburban, everything bolted straight together. The transmission even bolted straight up to my 6.2L without any adapters either. I didn't even have to change my driveshafts!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-07-2009, 09:55 PM   #10
nekkidhillbilly
what trucks have this transfer case and a 4l80 will bolt to it
Old 04-07-2009, 11:34 PM   #11
Russell
Professional Grade
Russell's Avatar
You can bolt any 32 spline NP208 or 32 spline 6 bolt round pattern NP205 from any 81 - 87 truck, Burb, K5 or 3+3, or any NP241 from an 89-91 Burb, K5 or 3+3 up to a 4l80e
Old 04-08-2009, 12:56 AM   #12
nekkidhillbilly
really ok then my is a 84 k20 with a 205 so it should just bolt right in
will i have to move it back or anything
Old 04-08-2009, 09:22 AM   #13
Russell
Professional Grade
Russell's Avatar
So long as your NP205 is 32 spline then it should bolt right up to the 4l80e. I don't know the exact length of a 4l80e, so I am going to side on the edge of caution and say you should expect to be replacing your transmission crossmember, and having to adjust the length of your driveshafts.
Old 04-08-2009, 06:18 PM   #14
nekkidhillbilly
truck is a 3/4 ton them and the th400 are pretty close so i could move the engine a foward if needed
