Old 03-17-2003, 08:19 PM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Question Replacing cab mounts............
I ordered a new set of P-S-T polygraphite cab mounts. How should I go about replacing them? Aside from removing the bolts and etc., what else needs to be removed? Thanks for any suggestions.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 03-17-2003, 08:41 PM   #2
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
just hope your bolts come off and dont spin like mine did...never replaced them .
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 03-17-2003, 08:41 PM   #3
bigd65
bigd65's Avatar
just jack it up with the floor jack , enough to clear the mount from the body, they are real simple to change
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 03-17-2003, 09:33 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
I already removed the two rear bolts and no problems. Once all the bolts are removed, the cab will lift up w/o trouble? Being that there are bushings on both sides of the actual steel mounts...???
Old 03-17-2003, 10:26 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
I recommend taking out two on each side and leaving the others in, but loose. This way, you will be sure the cab don't move with you and make a biotch to get the bolts started. Then jack up a side at the time, put in new ones, drop it back down, start the bolts, but leave them loose. Do the other side the same way.
Dave,
you will need to cut a hole in the floor to get yours out. No other way to do it. Then you can weld the nut back to the floor support, and weld a piece over the hole.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
