04-06-2009, 04:11 PM | #1 |
need 70 4x4 parts
edited by moderator
04-06-2009, 04:35 PM | #2 |
Re: need 70 4x4 parts
I'm not sure but that is probably a wreaking yard only item. I believe that even the 2 WD with leafs will work.
69 Chevy 4x4 383 Power Last edited by Longhorn Man; 04-06-2009 at 10:23 PM. Reason: removed the quote from the initial WTB |
04-06-2009, 04:53 PM | #3 |
I have a pair of the u-bolt plates off a 70 1/2 ton pick-up.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
04-06-2009, 04:55 PM | #4 |
how much?
04-06-2009, 04:56 PM | #5 |
$25 plus shipping.
Gary
04-06-2009, 05:00 PM | #6 |
souds good to me. give me a call 215 805 4851 and we can work out the details or leave your number and I'll call you. My name is jeremy
04-06-2009, 05:04 PM | #7 |
jeremy
Give me a day or so. I have another set, and want to make sure there both from a 1/2 to and see witch ones are in the best shape for you. Then I'll send you a PM. Gary
04-06-2009, 05:07 PM | #8 |
very cool. thanks alot and I'll talk to you tommorow.
04-06-2009, 05:14 PM | #9 |
I went down in the basement and found them right away. Both are for 1/2 ton and on set looks very good, surface rust only, no scaley rust. Just to be sure ?
You have the ones that go under the axle with the squared off u-bolts the drop down from the top over the leaf springs ? Gary
04-06-2009, 06:21 PM | #10 |
I will have to check later tonight and get back to you in the morning but I know they are under the axle and the u bolts drop down from above.
04-06-2009, 07:40 PM | #11 |
I had the same question about a week ago. I found some in local spring shops. I haven't bought them yet so I don't know the quality but they may be better than originals from what I saw on websites.
04-06-2009, 08:47 PM | #12 |
I am still going to buy the set from custom/10 for now, but let me know how the others look after you get them. If they are good quality and look like a heavier duty set I may get them later as I plan on a lift kit down the road.
04-06-2009, 09:11 PM | #13 |
Designated A-hole!
I see several problems with this thread. First you need to be a subscriber to post a WTB. Second all buying/selling belongs on the parts boards, whether you're a subscribed member or not.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
