Old 04-06-2009, 09:36 PM   #1
fdbdw
fdbdw's Avatar
hei issue
Anyone else run into this problem, just dropped in a 65k hei from Skip White, the vacum advance hits the manifold and blocks the manifold vacum port, Im hoping that once I get it wired up and timed that the correct timing postion will take the vac adv far enough clockwise to get it out of the way, anyone else have an issue with this
fdbdw is offline   Reply With Quote
Old 04-06-2009, 10:11 PM   #2
berencam
berencam's Avatar
Re: hei issue
Yea thats how it was for me too, i just put an elbow on it and pointed it the other way, i used a fuel line to attach to the elbow to give something for the hose to go over. Here is the elbow i used, although its not pointed that way anymore. i have it pointed to the drivers side.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-06-2009, 10:29 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: hei issue
why is the vacuum can off by almost 1/4 turn? I would stick with a good GM HEI.
68C15 is offline   Reply With Quote
Old 04-06-2009, 10:37 PM   #4
oldsub86
Re: hei issue
Can't you just move the plug wires all over one hole and then move the whole distributer back some?
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 04-06-2009, 10:37 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: hei issue
Isn't that just related to how it's stabbed in? I've heard nothing but good stuff abut SW HEI's.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-06-2009, 10:42 PM   #6
Boog
laying low
Boog's Avatar
Re: hei issue
Yes. As far as where the vacumn can is located it is just a matter of pulling the dist out, turning the oil pump shaft clockwise just a bit and reinstalling the dist with the can turned more to the rear. No need to move plug wires that way.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-07-2009, 07:36 AM   #7
fdbdw
fdbdw's Avatar
Re: hei issue
wouldnt you have to move the oil pump and the plugs, cause if you took it out at #1 tdc then move turned the oil pump and put it back in, the rotor will be pointed at a different plug
Old 04-07-2009, 07:59 AM   #8
rockc
Re: hei issue
Sounds like you are off one tooth on the cam with the dist.
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 04-07-2009, 08:53 AM   #9
dznucks
dznucks's Avatar
Re: hei issue
Mine is pointed just like the one in the pic. you should be able to get it close to see where it will sit before cranking it. if its not pointing the right way you are off a tooth.
dznucks is offline   Reply With Quote
Old 04-07-2009, 10:30 AM   #10
Boog
laying low
Boog's Avatar
Re: hei issue
No need to move the plug wires, just turn the dist clockwise to line the rotor back up on number one terminal. Doing this moves the vacumn can further away from the intake so to give you some adjustment room.
Also, it may be easier for some to just move the plug wires around 1 terminal on the dist cap then readjust the timing.
Boog
primer is finer
