04-07-2009, 04:16 AM | #1 |
Fuel Gauge Question
I have been running an auto meter fuel gauge and I would like to switch back to the stock one.
I have a ez-wire harness and I am not using the circuit board on the cluster. so what terminal is for what? there are three on the back of the gauge. So lets say you are looking at the cluster from the back and the fuel gauge is on the right there are two on top and one in the middle below them. what is what Top Right: Top Left: Lower: Thanks guys!!!
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
04-13-2009, 03:43 PM | #2 |
Re: Fuel Gauge Question
bump
04-13-2009, 04:14 PM | #3 |
I really hate wet sanding!
not sure how you would wire it with an aftermarket harness and no circuit board. the two upper studs are for wiring the gauge, the lower middle was to hold it in the gauge pod, and probably ground the gauge also. I have had a couple apart and the lower stud has no wiring connection. Also the 2 uppers have a diode of some sort attaching the 2 together. I am guess one side is hot lead and other is for the fuel tank sender. I don't know if matters which way it is hooked up, I do know that a gauge head from an 85 chevy will bolt right in and work, looks pretty cool to, changed it on my buddies truck, also swapped in the face to the 85 speedo, wet sanded the 69 numbers off the gauge lens and buffed it out. Will try to get a pic if anyone wants to see how it looks.
04-13-2009, 04:30 PM | #4 |
ok cool, thanks for the help, i just dont want to hook it up backwards and burn out the sender!
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby Last edited by Wilson_; 04-13-2009 at 04:30 PM. |
04-13-2009, 06:42 PM | #5 |
dazed and confused
i would like to see a picture of that
members met: redbaron69, billsbowtie,nc67 |
