Old 04-07-2009, 10:36 PM   #1
americanmusc1e
americanmusc1e's Avatar
No gauge lights!!!!
Driving home tonight and hit a bump and my headlights flashed off and came back on but my gauge lights went off and didn't come back on. Haven't been able to check it out yet. I messed with the dimmer switch, the voltage regulator and the plug going into the back of the dash but I couldn't get it to work.
Any Ideas at what it could be.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 04-07-2009, 11:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: No gauge lights!!!!
do your brake lights/parking lights/dome light work... or did they all go out?
Old 04-08-2009, 01:30 PM   #3
soba_03
soba_03's Avatar
I believe that your saying you messed with the plug to your dash/gages. I would look at your headlight switch plug, sounds like maybe it shook loose or has a little corrosion. Pull it off and back on a few times should solve your problem...
soba_03 is offline   Reply With Quote
Old 04-08-2009, 03:01 PM   #4
americanmusc1e
everything works except the gauge lights, even the gas gauge works
-- Josh
Old 04-08-2009, 03:08 PM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
it working and I looked forever for a cause. I replaced the headlight switch and they work fine now. The reostat that controls the brightness went bad.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
