Has anybody had any luck with replacing the double driveshaft in a 66 with a single piece shaft? I'm getting really tired of dealing with that center support bearing. I have a TH350 behind a 327. Is there a junkyard shaft that I can bolt in, or one that I can have cut down and rebalanced? I obviously prefer one that I don't have to mess with. Does the driveshaft loop ever create clearance problems with a new shaft?
my 66 shortbed gmc parts truck with leaf rearend had a 1 piece i think,,,
atleast it didnt have any driveshaft loop part etc i dont have the driveshaft from it but maybe you should look for a leafspring truck? ------------------ xframeimpala.com 68 4x4 short fleetside deluxe cab 327 air 56 big window short stepside 64ImpalaSS 68 large journel 327 turbo 350 |
The short beds I have owned always had the one piece drive shaft. You didn't say if you had a short or long bed. Plus I have not seen the loop cause any clearance problems except for exhaust routing.
Good luck ------------------ 67 SHORT STEP 396/Powerglide, 3.73's All the normal go fast goodies. Power discs and power steering. Needs AC 2000 Silverado 1998 Nissan Frontier
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
It's a longbed.
Open Sundays 10 till 10
I have had and have a lwb truck with built motors. I hate those carrier bearings they really suck. I have heard late model one piece driveshafts will work, but i've never seen it done. I was almost certain that the angle you would put your driveshaft at would wear out your pinion seal on your rearend.
As lame as this advice is. I carry a spare driveshaft in my truck complete set up bearing and all. I'm wondering myself if i installed a long tail 350 turbo with a custom built driveshaft would it work. Probably have to do some torching on the crossmember and reinforce frame in another spot. I'm open for suggestions.
817-846-5476 parts for sale always 30 minutes south of Dallas on I35 WWW.BBSAutoSalvage.com bbs1969@direcway.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
