Old 04-06-2009, 08:29 PM   #126
GRIMSS
GRIMSS's Avatar
Re: so lets build a truck/my '52 chevy
Man that is nice.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-06-2009, 09:17 PM   #127
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Wow!!!!!!!!!!!!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-07-2009, 09:59 PM   #128
cajundragger
thanks homies
more more...
bed
mounting mirrors
mounted
rubber on hood jam
tagged wiring to bed
made rear fender braces. I know, I forgot to black out the rear fenders before they got mounted, so I need to tape them off and paint them.
finally, the hood.
cajundragger is offline   Reply With Quote
Old 04-07-2009, 09:59 PM   #129
cajundragger
I did a bunch of other random stuff today, like heicoil the transmission, but I didnt get pics.
also I rotated the mirror glass around on the pivot to bring them in closer after I noticed they were lookin funny, lol.
Old 04-07-2009, 10:01 PM   #130
STOUTE
Sick
STOUTE is offline   Reply With Quote
Old 04-08-2009, 10:52 AM   #131
Daniel U
Daniel U's Avatar
Very nice!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 04-08-2009, 08:43 PM   #132
youngrodder
youngrodder's Avatar
Cajun-
Looking good. Did you make the tail light brackets? They look like they were machined. Very slick.
What mirrors are those? They look similar to some I was looking at from Socal speed shop.
Marc
youngrodder is offline   Reply With Quote
Old 04-08-2009, 09:06 PM   #133
hotrod386
nice work, were did you get a t56 centering kit from? i`ve looked everywere thanks
hotrod386 is offline   Reply With Quote
Old 04-08-2009, 10:05 PM   #134
cajundragger
thanks guys.
Originally Posted by youngrodder View Post
Cajun-
Marc
the tail light brackets I made from some 1/8 aluminum. Just cut them on a bandsaw and filed. then drilled some holes and sanded them with a DA with 80 then 180 grit.
the mirrors you saw are probably the same if not very similar. I dont remember where I got them. I got the mirrors and the pedal from the same supplier.
the kit came from keisler. It was hard and nerve racking to install as the whole trans has to be taken apart and the main shift rail has to be to cut and drilled. It is harden steel and took an $80 drill bit to drill it.
Old 04-11-2009, 08:50 PM   #135
pgf545
pgf545's Avatar
Cajun, Very nice work....can't believe you are so young and doing this great work.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 04-12-2009, 03:52 PM   #136
TheEstablishment
Fantastic build, Cajundragger!
Do you by chance have pics of your bed build? The tailgate/rear pan setup is really slick.
TheEstablishment is offline   Reply With Quote
Old 04-12-2009, 11:45 PM   #137
cajundragger
here you go
should start from the beginning. Its stock dimensions, except the bedsides are stretched 2" straight up. The tailgate is left stock length to keep proportions. then I made a hidden hinges using strut bushings and crush sleeves.
[img]http://pic60.picturetrail.com/VOL1731/8270596/15446429/243207734.jpg[img]
Old 04-12-2009, 11:47 PM   #138
cajundragger
Old 04-12-2009, 11:47 PM   #139
cajundragger
any questions just ask.
Old 04-16-2009, 08:44 PM   #140
TheEstablishment
Very nice, thanks for the detail! I wouldn't have noticed that the bedsides were higher. I think it flows with the body lines better.
The guy I bought my truck from included some custom bedsides fabbed up from 10 ga. steel, and tubing welded onto the top. They look a lot like yours.
It looks like your tailgate hinges are on the inside? That's a nice touch.
Old 04-17-2009, 12:13 AM   #141
cajundragger
they are. It works really well.
worked on my air gauges. I refuse to advertise for kp components so I made my own faces with a shop name I dont mind advertising for lol.
this is the lip i cut to open it up..
taped the lens
cut
all apart
bunch of faces
glued on to the aluminum blank
glued on stops
face on gauge
needles
buckets
Old 04-17-2009, 12:14 AM   #142
cajundragger
bezel
glass
this is what it looked like before I cut it..
Old 04-17-2009, 07:15 AM   #143
GRIMSS
GRIMSS's Avatar
Nice touch on the color matching and custom face.
2001 GMC SIERRA
1968 Camaro
Jared
Old 04-17-2009, 10:12 AM   #144
TheEstablishment
I just realized I said 'hinges' when I really meant 'chains'. Are you using the chains to latch the tailgate like they did stock?
Also, as an engineer, I must say that's got to be one of the best ways to study for a math test that I've seen! The custom touches really add up.
Old 04-17-2009, 10:53 AM   #145
cajundragger
no I have these push locks from pros pick.
http://www.pros-pick.com/hiddenlatchkits.html
yeah the bed was confusing to keep it all working right. I also didnt want any wheel tubs so that was hard to get all that correct as well.
Old 04-20-2009, 01:55 AM   #146
cajundragger
cleaned it up, changed the lugs to the bullets, and mounted the bumpers. I tucked the rear bumper 3.25"
stock rear-
tucked-
front
general pics
Old 04-20-2009, 01:56 AM   #147
cajundragger
Old 04-20-2009, 07:25 AM   #148
GRIMSS
GRIMSS's Avatar
Looks great tucked up close.
2001 GMC SIERRA
1968 Camaro
Jared
Old 04-27-2009, 09:52 PM   #149
cajundragger
my buddy Jeff got me some pics of the truck from the show we went to since I forgot my camera. I got some striping done while I was there, pictures dont even begin to do them justice as they dont pick up the colors at all. The one on the tailgate is actually 3 colors.
hey grim, if any of these pics seems photoshopable let me know which ones and pm your email address and I can email them if you want to play with the wheels.
Old 04-27-2009, 11:09 PM   #150
GRIMSS
GRIMSS's Avatar
The stripes look sweet. I'll PM you on the pic.
2001 GMC SIERRA
1968 Camaro
Jared
