04-12-2009, 01:51 AM | #1 |
Welding axles
I have two projects going at once so I have to start cutting corners with my truck a little. At first I was going to order a 5 lug axles for a 69 rear but now I want to reuse old axles. What do you guys use to weld the axles? Will a mig work or do I need something hotter?
04-12-2009, 02:42 AM | #2 |
Re: Welding axles
As long as its a big enough MIG. I wouldnt use anything smaller than a 175 amp 220v unit.
04-12-2009, 06:52 AM | #3 |
Re: Welding axles
r u thinking about chopping up and trying to shorten the axels?? IT AIN'T GOING TO WORK
04-12-2009, 09:43 AM | #4 |
Re: Welding axles
Dont do it,,, trust me , vince
04-12-2009, 09:49 AM | #5 |
its all about the +6 inches
Re: Welding axles
we need more info here... exactly what is it you are trying to do?
04-12-2009, 10:03 AM | #6 |
Re: Welding axles
Axle tube ya it will work axle shaft it may but I don't see it lasting long if you like to push on the gas. I have seen a dana 60 axle snap,just from slipping on dirt at the side of the road onto pavement because it was welded.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
04-12-2009, 10:18 AM | #7 |
Re: Welding axles
If he was shortening the axles he would need a saw, not a welder?Is he is talking about plug welding the 6 lug holes and drilling it for 5 bolt? Maybe not ? never was good at Algebra?
04-12-2009, 11:28 AM | #8 |
Re: Welding axles
algebra i think has nothing to do with laying out boltpatterns,geometry is what i'd put to use
04-12-2009, 11:39 AM | #9 |
Re: Welding axles
well cutting a axle and welding the spline back on will not give you a dependable axle
04-12-2009, 11:54 AM | #10 |
Re: Welding axles
welding the holes sure want make it stronger , leaveing the old studs in an cutting them off would be my fix,,, vince
04-12-2009, 01:07 PM | #11 |
Re: Welding axles
I have a 69 rear with 6 lug axles. I want to weld it and redrill to 5 lug pattern.
04-12-2009, 01:36 PM | #12 | |
Re: Welding axles
WELD WHAT???//yoke cover saddles tubes avel shafts ???// if its just a matter of welding up the lug holes you b better off using the old studs as filler
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-12-2009 at 01:38 PM. |
04-12-2009, 01:39 PM | #13 |
Re: Welding axles
OOooops I was thinking housing, yeah dont weld axles themselves.
04-12-2009, 03:28 PM | #14 |
Re: Welding axles
