Old 03-18-2003, 04:37 PM   #1
firemanchuck
FightingFire Saving Lives
How To Identify My Axles
HEY CHEVY BROTHERS,
JUST CURIOUS HOW I CAN IDENTIFY MY AXLES ON MY BABY.
THE GLOVE BOX DOOR IS TELLING ME 3:73 WILL THAT BE FRONT AND BACK, IS THERE A STAMP SOMEWHERE ON THE AXLE'S THAT WILL CLEAR THIS UP FOR ME. I JUST WANT TO MAKE SURE SHE HAS THE ORIGINAL AXLES. JUST NEED TO KNOW WHERE TO LOOK.
THANKS FELLERS.
FIREMANCHUCK, TULSA, OK
1972 4X4 FLEETSIDE SWB 350 SMC 4-SPEED
firemanchuck is offline   Reply With Quote
Old 03-18-2003, 05:07 PM   #2
landon4421
Life is Good !
landon4421's Avatar
I know if you take the covers off there are #'s on the ring gear, if you post those #'s someone will be able to help you. That's the way I have always checked them.
Welcome to the board, Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 03-18-2003, 06:00 PM   #3
Blue Beard
Blue Beard's Avatar
Generally, there would be a code on the axle housing. About 6" out from the main housing..............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-18-2003, 06:05 PM   #4
Yukon Jack
Yukon Jack's Avatar
The front axle should be a Dana 44 and will have D44 stamped in the webbing on one side of the differential. Not positive of markings on the rear axle. It is not uncommon to find a slightly different gear ratio in the front axle than the rear axle, usually just off by .01.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-18-2003, 06:51 PM   #5
1972chevy4x4
1972chevy4x4's Avatar
If they are 3.73 gears there will be a 41:11 stamped on the gear inside of the pan. I would go ahead and pull pan to check, being a 30 year old truck probably could use some new oil.
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete
1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine"
1990 GMC 3/4 shortbed ext cab
Always in need of 67-72 parts in central ks.
1972chevy4x4 is offline   Reply With Quote
Old 03-18-2003, 07:43 PM   #6
HeavyK20
HeavyK20's Avatar
That's 41 teeth on the ring and 11 teeth on the pinion. 41/11=3.727272 or 3.73 Just had to throgh that out there because its the one thing in the world that I know.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 03-19-2003, 06:01 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If they are stock they should be a Dana/Spicer 44 up front and a GM 12 bolt in the rear.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
