04-12-2009, 10:16 AM | #51 |
SSN 706
Re: Daverods project 66
04-12-2009, 10:21 AM | #52 |
Looks so nice
I like bare metal, but love the look of some nice primer I have read you need to seal the metal first before priming, but then I have also read you can apply it to bare metal...so maybe it don't matter which way you do it. the internet is great but you get so many different contradicting opinions....kinda confusing at times
CHEVY ONLY Last edited by joe231; 04-12-2009 at 10:22 AM. |
04-12-2009, 10:29 AM | #53 |
SSN 706
My first words when I walked in the paint store were " I need a primer that I can put on bare metal". She told me that was the stuff?
04-12-2009, 10:53 AM | #54 |
Daring to be Different
I think if your going paint it right away you can use a metal primer. If you have body work to do you then have to seal it first so it won't rust. Again I said "I think". What do you guys think?
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
04-12-2009, 11:09 AM | #55 |
SSN 706
My plan (do I have a plan) was to prime, do my body work (Rage body filler) then Slick sand, then paint? Mayde I have to seal the slick sand. I'm not sure. I was looking on evercoat web site the orginal featherfill says you can put it on bare metal. This stuff says g2 on in. I think that just means it can be used over a eching primer? I'm confused.
04-12-2009, 11:28 PM | #56 |
SSN 706
Worked on my doors today. Took the windows out, sanded the paint off, began to wonder if you can ever stop the rust? Used about 3 can off rust stop, hay it can't hurt. Sprayed it inside the doors, around and inside the hood, all the places I could'nt sand or sandblast. I'm going to see if I can get these doors to work. I don't really want to spend the money to buy new ones. Should be getting my engine back from the machine shop this week . It's a 350 bored .10 over. I have a turbo 350 and a 400. I think I'll use the 350. Did'nt really need to do the engine now but it just somthing else I can check off the list. Still looking for a steering column.
04-12-2009, 11:29 PM | #57 |
Man I'm glad I live in California with all the rust I've seen here. The etching/sealer primer that I use can have bondo over it.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 04-12-2009 at 11:31 PM. |
04-12-2009, 11:35 PM | #58 |
SSN 706
04-13-2009, 12:04 AM | #59 |
60-66 Nut
If Evercoat says it is a direct to metal primer, and you followed the prep recommendations, you should be fine. Whenever I'm working with blasted metal I first spray it with epoxy primer, then do the necessary filler work, and then start with the sandable primer. This is just what I've done for years.....learned it from a few local restoration and custom car builders.
04-17-2009, 09:09 AM | #60 |
SSN 706
Worked on my body work alittle last night. Seemed like all I do is put filler on then sand it all off. Ordered some new door bottoms from lmc. Going to pick up my engine from the machine shop today.
04-17-2009, 10:00 AM | #61 |
Ain't that a *****, all that blocking & sanding. Looken good. Keep it up Dave.
04-17-2009, 10:10 PM | #62 |
SSN 706
Won a tilt steering column on ebay I'm pumped. Came out of 79 chevy van. Now I can finish mounting my dash. Picked up my engine, cleaned out a spot in my garage to work on it. Now all I have to do is find the time to put it together. It's my first one so it might take awhile. Feel free to tell me what to do first.
04-17-2009, 10:17 PM | #63 |
1 thing at a time is progress.
I hope your done sand blasting. Engines and sand don't mix well. I've rebuilt several chevy engines. I used "How to rebuild a small block chevy" if you follow it everything should work out fine. Cleanliness and order and recheck your work. It's simple to do just tedious.
Alan
Philippians 2:14-16 |
04-17-2009, 10:22 PM | #64 |
SSN 706
There will be no more sand blasting inside my garage ever! Took about a week to clean it out. I'll have to get me one of those how to books. Thanks Allen sorry about Grandma.
04-17-2009, 10:34 PM | #65 |
SSN 706
Just bought a how to book on Amazon used $9. Money well spent I'm sure. I've rebuild a few snowmachine engines so I have a little idea of what to do. Probably just enough knowledge to get in trouble.
04-17-2009, 11:36 PM | #66 |
Resistance is Futile
There are many knowledgeable people over in the engine section of this website. Ive read quite a bit over there, so if you have an issue you can post it up over there.
Looking good on the progress......I hate sanding.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-18-2009, 08:01 AM | #67 |
It looks like you are making good, steady progress. Let us know how the engine assembly goes and keep up the good work.
04-18-2009, 08:55 AM | #68 |
Watch out for your cornhole !
Make sure the machine shop put that little galley plug back in place under the oil pump driveshaft area (ish...hard to describe. You should see it when looking in that area. Little feller, about 1/2 an inch if I remember right.). They remove them to vat the block.
It's happened a lot over the years. Forget that little plug and it won't build oil pressure. Big pain.
04-18-2009, 09:09 AM | #69 | |
SSN 706
04-18-2009, 09:29 AM | #70 |
SSN 706
I think it this is what your talking about Tx?
04-18-2009, 09:33 AM | #71 |
Look straight down into the engine bowels in this area.
It should likely be a shiny new little bitty freeze plug.
04-18-2009, 09:36 AM | #72 |
And that rusty thing sticking out of the block near the oil pan rail in your picture. That is some goofy unknown something or another. Unscrew it and replace it with a 1/4 npt plug. That's the lower drain for the block water galley.
04-18-2009, 09:46 AM | #73 |
SSN 706
I see nothing. I don't think they put it back. Maybe it's in the gasket kit?
04-18-2009, 11:22 AM | #74 |
It's been afew years, so I'm dealing mith my memory here...
I do believe you might have to remove the rear main cap to see the area better. It's up in here somehwere. I promise, I'm not getting Alzheimers yet. You will know it immediately when you see it. I think it's somewhere next to where the oil pump rod goes into the block.
04-18-2009, 04:04 PM | #75 |
SSN 706
hay hay hay. And to think I was beginning to doubt you. That's it right? One less thing to worry about. Thanks Kevin
