Old 04-12-2009, 03:04 PM   #1
B52fizzle
B52fizzle's Avatar
Question dodge dana axle swap
found two sets of dana 60's 70's SRW both in 90-93 dodge rams , one has 3.54 gears so wouldnt that be a dana 61? not sure of other but since it is close in year what are the chances of it being a 61 also? dont know what dodge used can also get transfer case and automatic transmission with 12 valve cummins diesel, what parts can i swap into a chevy blazer or pickup, or would it be best to just mount my 1970 c20 cab on the dodge frame any body try that before? i know anything can be done but with limited fabrication equipment and time should i just grab the axles and transfer case and run with that?
99 1500 5.3 daily driver
70 c20 307 project
74 cheyenne super10 suburban 454 my highschool baby.
62 willy's wagon sans drive train distant project
B52fizzle is offline   Reply With Quote
Old 04-12-2009, 04:30 PM   #2
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
Re: dodge dana axle swap
If it was a 61 it would have 3:07 gears as it was the only ratio offerd in a 61.That was the reason for a makin a 61 was to get a higher ratio in the housing.The case will be a 23 spline figure eight pattern 205 and will not work on any Chevy trans without a input swap.If it was cheap I would get it to sell and offset the price of the axles.The Dodge front will work under a Chevy it's just a tad bit wider on the ps(1.5 or so IIRC).
1-tonmudder is offline   Reply With Quote
Old 04-12-2009, 07:15 PM   #3
skchevota
skchevota's Avatar
Yup, Dana 60, the doge fronts are 1" wider on the spring purches, the tranfercase is a 205 and the tranny, I forgot the # but it is basicly a 727 with overdrive, a year or so later they went electronic.
skchevota is offline   Reply With Quote
Old 04-12-2009, 07:18 PM   #4
B52fizzle
B52fizzle's Avatar
how do body mounts compare for a body chassis swap?
70 c20 307 project
Old 04-12-2009, 08:55 PM   #5
1969 GMC
1969 GMC's Avatar
I may be wrong, but I think some of the 61's had 3.54 gears also. I know if it has 4.10's it isn't a 61. The best way to check is to run the bill of material number in dana's website.
Don't junk it if it is a 61, there are ways to make it useable, but I am tired and can't think of a good way to explain it at the moment. If you search over at pirate4x4, I know it is covered there.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-12-2009, 08:59 PM   #6
1-tonmudder
IIRC you have to use a 4:56 up carrier and a gear spacer to use 4:10's.It's been a while so I might be mistaken.
Old 04-14-2009, 09:39 AM   #7
Jtrux
I'm a poor spectator
Jtrux's Avatar
Can't you just move the spring perches????
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-14-2009, 06:54 PM   #8
1969 GMC
1969 GMC's Avatar
On a d60 front axle, at least what he is talking about, the spring perch for the passenger side spring is part of the pumpkin.
1969 GMC K2500
1996 Honda Accord
