Old 04-13-2009, 07:45 PM   #1
Sicmaro
Always wrenching!!
Sicmaro's Avatar
Reverse light help.....
My lights don't work. bulbs are good, fuses are good. Do the lights get activated by a switch in/on the column or from the tranny? any one have a good wiring diagram off the reverse light circuit?? thanks in advance.
and FYI.......... the truck now has a 4l60e trans..... but the lights didn't work before the engine/trans swap.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 04-13-2009, 07:55 PM   #2
Legolas894
Chemist under the hood...
Legolas894's Avatar
Re: Reverse light help.....
On the three speed column shift, the switch is near the bottom of the column under the dash. On my truck, the guy converted to floor shift and installed a toggle switch to turn on the reverse lights!!!
Legolas894 is offline   Reply With Quote
Old 04-13-2009, 09:53 PM   #3
Sicmaro
Always wrenching!!
Sicmaro's Avatar
the toggle switch crossed my mind, but if the switch is on the column then i should be able to fix it up.
Any one have any pics of the switch and a wire diagram??
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-13-2009, 10:14 PM   #4
Legolas894
Legolas894's Avatar
Here's a diagram from my 1967 Shop Manual. Hope that helps.
Old 04-13-2009, 10:22 PM   #5
tim21391
tim21391's Avatar
on my eclipse they didnt work so i put new switch on tranny and they worked... maybe its that
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-13-2009, 10:43 PM   #6
MonteSS454
MonteSS454's Avatar
You neutral safety switch needs replaced. 2 screws and its out, it's at the very bottom of your column. Try and start it in gear and if it does the switch is out. If it doesn't then check your connections on the switch.
MonteSS454 is offline   Reply With Quote
Old 04-13-2009, 11:25 PM   #7
kamikazekyle05
kamikazekyle05's Avatar
I just recently got mine working. After making sure the grounds were good the lights still didnt work. Bulbs, fuse, lights, and ground were good. Turns out the prongs that hold the fuse in, were dirty and not getting a good connection. Might be something to look into to
kamikazekyle05 is offline   Reply With Quote
