04-14-2009, 12:48 AM | #101 |
Re: Rear bag mounting pics please
the panhard bar hits the frame way before the axle bottoms out in the c-notch, you could get by without it but they are not that expensive.
04-14-2009, 01:05 AM | #102 |
i'll come up with some pics, another thing is the rearend is less than a inch from the bed floor.
05-06-2009, 08:12 AM | #103 |
I'm new to the airbag suspension idea. Are the metal beams to the differential and axle for making sure the driveshaft doesn't pop out? I'm curious because I'd like to know if I need to price out the cost of putting that on a truck I want to raise from stock to 4" and back down. Thanks.
09-05-2011, 06:04 PM | #104 |
09-05-2011, 08:53 PM | #105 |
No it will be just fine.
09-05-2011, 09:38 PM | #106 |
ok.. question.. how wide are the cups??
11-17-2011, 07:39 PM | #107 |
how many psi do you folks run the bags at?
11-17-2011, 08:50 PM | #108 |
Square
I run 3/8 line and my compressor turns on at 160 psi and turns off at 200 psi.
Squarebody Syndicate |
11-17-2011, 09:35 PM | #109 |
GM ONLY BABY!!!
I have Re7'z IIRC and I run mine about 70 psi. on my 72 GMC 1500 LWB. I have 1/2" line with comp's on at 140 and off at 160, I think.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
11-18-2011, 11:00 AM | #110 |
Stirrer of the Pot
I never even bothered putting a gauge on my bags. I just aired them up to ride height, more or less, and drove.
11-18-2011, 11:29 AM | #111 |
So would i be correct saying that sleeve style bags are better for over the axle mounting and that double conv. bags are good for mounting on trailing arms?
11-18-2011, 11:48 AM | #112 |
Correct.
12-31-2013, 07:37 AM | #113 |
Anymore custom bag mounts & frames?
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
01-02-2014, 11:34 PM | #114 |
I am gathering parts up to do a four link with phb and bags on my c10. Is there any way to help determine how tall the bags will be with and what psi they will need for good ride quality?
